  • bh 444 posts 1544 karma points
    Aug 22, 2024 @ 13:51
    bh
    v14.2 ApiError Method Not Allowed
    I get the error notification "ApiError Method Not Allowed" anytime I try to save anything in Umbraco. I was getting this error previously and fixed it by updating my http > https URL rewrite. But, that isn't working now.
    I tried removing my http > https rewrite rule altogether...I still get the error.
    There's nothing in the logs. Nothing in event viewer on my server. I've checked IIS and I'm not blocking any verbs.
    It works fine locally, but fails on my server. I'm running probably 80 other Umbraco (< v14.0) sites on that server.
  • Ole Andreas Myhre Olsen 15 posts 85 karma points
    Aug 28, 2024 @ 13:05
    I got this error after deploying a site and running uSync. I have not found any way to fix this 🤷‍♂️
    Aug 28, 2024 @ 13:23
    bh
    @OleAndreasMyhreOlsen I have uSync on mine too. Interesting. Taking a shot here @KevinJump you have any insight on what might be causing this result?
    Aug 28, 2024 @ 20:24
    bh
    @OleAndreasMyhreOlsen I just spun up a minimal v14.2 site without uSync and this error still exists. It's an Umbraco issue, not a uSync issue.
    Aug 29, 2024 @ 06:52
    Thanks for testing without uSync.
    I wonder why uSync manages to create document types and content while I cannot do it as administrator?
  • Sebastian Müller 3 posts 76 karma points
    Aug 30, 2024 @ 06:39
    Sebastian Müller
    3
    Hi everyone,
    I ran into the same problem and was able to fix it by disabling the WebDAV module for this specific web app.
    <system.webServer>
       <modules>
          <remove name="WebDAVModule"/>
       </modules>
    </system.webServer>
    Maybe this fix will work for you as well. :)
    Sep 02, 2024 @ 07:30
    Thx!
    I wasn't aware that I had one 🙈
    But this can be marked as solution 😃👏👏👏
  • nguyen luan 1 post 21 karma points
    Dec 29, 2024 @ 12:48
    nguyen luan
    in v15, this still working. I dont understand why this, but is good practice.
    Aug 30, 2024 @ 07:19
    What version are you refering to, Sebastian? Looks like web.config
    I managed to reproduce the error on local machine by messing up the Id in appsettings.json
      "Umbraco": {
        "CMS": {
          "DeliveryApi": {
            "Enabled": true
          "Global": {
            "UseHttps": true,
            "Id": "",
            "SanitizeTinyMce": true
    Aug 30, 2024 @ 08:01
    Nope, that was not it!
    Aug 30, 2024 @ 07:30
    Sebastian Müller
    It's the web.config file that IIS automatically generates when creating a web application. It is located in the web root directory.
    Aug 30, 2024 @ 12:27
    I cleaned the db and deployed again, and that worked for about 2 minutes. Then the error came back.
    I'm deploying to a loadbalanced environment, does that have anything to do with it?
    Aug 30, 2024 @ 14:12
    bh
    @OleAndreasMyhreOlsen you would need to make sure that the web.config on all servers have the new web.config change proposed by @SebastianMüller
    I'd love to test this as it looks like a simple fix, but just yesterday after messing with this for 2 weeks I bailed on v14 and spun this site up as v13.
    @SebastianMüller what does that webdav config do in the context of Umbraco, do you know? Is it needed or does turning it off create a security vulnerability?
  • Paul White 1 post 71 karma points notactivated
    Nov 16, 2024 @ 19:00
    Paul White
    I have just run into this issue on a V14 website deployed on IIS. The web.config change immediately fixed the issue. Thanks Folks
  • Michael Nielsen 155 posts 812 karma points
    Nov 29, 2024 @ 10:26
    Michael Nielsen
    I've run into this issue also in v14.3.1 hosted on IIS.
    Disabling WebDAVModule fixed it 👍
    Is this an Umbraco bug, or something with IIS?
  • M Jamil 8 posts 88 karma points notactivated
    19 days ago
    M Jamil
    I have run into the same problem in V15.1.2 hosted on IIS.
    Disabling WebDAVModule fixed it for me.
