  • zhihai 2 posts 72 karma points
    Sep 12, 2024 @ 09:57
    zhihai
    Umbraco 13.4, how to set up Examine Index in a distributed environment
    Hi there,
    I have a Umbraco project, and the deployment is as follows:
    • 1 Umbraco instance for backend editors
    • 2 Umbraco instances provide high availability services to provide API services to frontend web applications
    • All 3 Umbraco instances connect to the same database and the same Examine index file directory to ensure consistency between the frontend and backend content
    Issues: The index in Examine Manager in Umbraco(backend) often fails and the index file is missing.
    Question: Could this issue be caused by file locks due to multiple Umbraco instances writing to the same Examine index file? If so, how can this be avoided, and how can I ensure that different Umbraco instances read the same index file without conflicts?
    Expecting your help, many thanks.
    Sep 18, 2024 @ 11:01
    zhihai
    Hi there,
    I hope one Umbraco could generate the index files in the shared folder, others only could read the index files from the shared folder.
    Expecting your support, thanks.
    Zhihai
