  • Ben Dickman 21 posts 103 karma points
    Sep 13, 2024 @ 08:15
    Ben Dickman
    DISTRIBUTED CACHE IS NOT UPDATED - missing content
    Hi all,
    I am running Umbraco 13.3.2 in Azure with the following configurations based on https://docs.umbraco.com/umbraco-cms/v/13.latest-lts/fundamentals/setup/server-setup/load-balancing/azure-web-apps
    Admin instance:
    • MainDomLock = FileSystemMainDomLock
    • LocalTempStorageLocation = EnvironmentTemp
    • LuceneDirectoryFactory = SyncedTempFileSystemDirectoryFactory
    Public instance:
    • LuceneDirectoryFactory = TempFileSystemDirectoryFactory
    The issue I am facing is content just disappears. Tabs go missing and text fields that did contain values are now empty.
    A restart of the Azure App Services restores the data but clearly this isn't ideal.
    The logs indicate the following:
    Error Log 1
    Microsoft.Data.SqlClient.SqlException (0x80131904): Lock request time out period exceeded.
    Error Log 2
    Umbraco.Cms.Core.DistributedLocking.Exceptions.DistributedWriteLockTimeoutException: Failed to acquire write lock for id: -331.
    Error Log 3
    Microsoft.Data.SqlClient.SqlException (0x80131904): Transaction (Process ID 83) was deadlocked on lock resources with another process and has been chosen as the deadlock victim.
    Error Log 4
    System.InvalidOperationException: This SqlTransaction has completed; it is no longer usable.
    And then the subsequent errors are all related to the missing content.
    Does anyone have any ideas what is going on?
    Many thanks,
    Ben
  • Jeavon Leopold 3074 posts 13632 karma points MVP 11x admin c-trib
    Sep 13, 2024 @ 10:07
    Jeavon Leopold
    Hi Ben,
    Have you checked the performance of your Azure SQL server, this error generally occurs when the SQL Server is out of resources.
    There are 2 settings you can adjust to allow more time before these errors occur, they go within Umbraco:CMS:Global
       "DistributedLockingReadLockDefaultTimeout": "00:01:00",
      "DistributedLockingWriteLockDefaultTimeout": "00:00:05",
    You can find them in https://docs.umbraco.com/umbraco-cms/reference/configuration/globalsettings
    It's also worth checking if you have any custom code using the DB to ensure it's using IScopeProvider and potentially also a lock https://docs.umbraco.com/umbraco-cms/reference/distributed-locks
    It maybe also be that you have a package installed that may be reading or writing to the DB incorrectly, so it might be worth auditing what's installed.
    Jeavon
    Sep 16, 2024 @ 09:13
    Ben Dickman
    Thanks Jeavon, I will give these a try.
