I am trying to add a new section and have 2 issues
1: When I set the following in code, it keeps loading the setting menu, when I click on the new section.
Code:
protected override ActionResult
var root = rootResult.Value;
if (root != null) {
root.RoutePath = string.Format("{0}/{1}/{2}", Constants.Applications.Settings, "housinginformation", "overview");
// set the icon
root.Icon = "icon-hearts";
// could be set to false for a custom tree with a single node.
root.HasChildren = false;
//url for menu
//root.MenuUrl = null;
return root;
But if I set root.RoutePath =null, then the menu loads as normal.
2: How do I remove the 3 dots at the end of the menu items as I do not beed a Add, Del, Edit menu options.
Here is the code for the full controller.
using Microsoft.AspNetCore.Http;
using Microsoft.AspNetCore.Mvc;
using Umbraco.Cms.Core;
using Umbraco.Cms.Core.Actions;
using Umbraco.Cms.Core.Events;
using Umbraco.Cms.Core.Models.Trees;
using Umbraco.Cms.Core.Notifications;
using Umbraco.Cms.Core.Services;
using Umbraco.Cms.Core.Trees;
using Umbraco.Cms.Web.BackOffice.Trees;
using Umbraco.Cms.Web.Common.Attributes;
using Umbraco.Cms.Web.Common.ModelBinders;
using Umbraco.Extensions;
public HousingInformationTreeController(ILocalizedTextService localizedTextService,
UmbracoApiControllerTypeCollection umbracoApiControllerTypeCollection,
IMenuItemCollectionFactory menuItemCollectionFactory,
IEventAggregator eventAggregator)
: base(localizedTextService, umbracoApiControllerTypeCollection, eventAggregator)
_menuItemCollectionFactory = menuItemCollectionFactory ?? throw new ArgumentNullException(nameof(menuItemCollectionFactory));
protected override ActionResult<TreeNodeCollection> GetTreeNodes(string id, FormCollection queryStrings)
var nodes = new TreeNodeCollection();
// check if we're rendering the root node's children
if (id == Constants.System.Root.ToInvariantString())
var node1 = CreateTreeNode("1", "-1", queryStrings, "Block Information", "icon-presentation", false,"housinginformation/housinginformation/blocks");
var node2 = CreateTreeNode("2", "-1", queryStrings, "Block Schedual", "icon-presentation", false,"housinginformation/housinginformation/schedule");
nodes.Add(node1);
nodes.Add(node2);
return nodes;
protected override ActionResult<MenuItemCollection> GetMenuForNode(string id, FormCollection queryStrings)
// create a Menu Item Collection to return so people can interact with the nodes in your tree
var menu = _menuItemCollectionFactory.Create();
//if (id == Constants.System.Root.ToInvariantString())
// // root actions, perhaps users can create new items in this tree, or perhaps it's not a content tree, it might be a read only tree, or each node item might represent something entirely different...
// // add your menu item actions or custom ActionMenuItems
// menu.Items.Add(new CreateChildEntity(LocalizedTextService));
// // add refresh menu item (note no dialog)
// menu.Items.Add(new RefreshNode(LocalizedTextService, true));
//else
// // add a delete action to each individual item
// menu.Items.Add<ActionDelete>(LocalizedTextService, true, opensDialog: true);
return menu; // null;
protected override ActionResult<TreeNode?> CreateRootNode(FormCollection queryStrings)
var rootResult = base.CreateRootNode(queryStrings);
if (!(rootResult.Result is null))
return rootResult;
if (root != null) {
// set the icon
//url for menu
return root;
Section
Code:
using Microsoft.AspNetCore.Http; using Microsoft.AspNetCore.Mvc; using Umbraco.Cms.Core; using Umbraco.Cms.Core.Actions; using Umbraco.Cms.Core.Events; using Umbraco.Cms.Core.Models.Trees; using Umbraco.Cms.Core.Notifications; using Umbraco.Cms.Core.Services; using Umbraco.Cms.Core.Trees; using Umbraco.Cms.Web.BackOffice.Trees; using Umbraco.Cms.Web.Common.Attributes; using Umbraco.Cms.Web.Common.ModelBinders; using Umbraco.Extensions;
namespace UmbracoCMS.App_Code.HousingInformation { [Tree("housinginformation", "housinginformation", IsSingleNodeTree = true, TreeTitle = "Blocks", TreeGroup = "housinginformationGroup", SortOrder = 0)] [PluginController("HousingInformation")] public class HousingInformationTreeController : TreeController { private readonly IMenuItemCollectionFactory _menuItemCollectionFactory;
Thanks Darren
