  • Kap 21 posts 173 karma points
    Sep 20, 2024 @ 15:00
    Kap
    Maintanance Mode Dashboard not showing on IIS
    Hi All,
    Im seeing something strange when deploying my website to IIS.
    Im running Umbraco 13.4.1, and under Visual studio, I used NUGet to install the Our.Umbraco.MaintenanceMode package. This works fine under Visual Studio, however when I publish the website to IIS, the Dashboard does not show, and I see this in the browser console:
    umbraco-backoffice-js.js.vc6e8bc0959901a75d8026fd6454b7729c35d534b:147  Error: [$controller:ctrlreg] http://errors.angularjs.org/1.8.3/$controller/ctrlreg?p0=maintenanceModeDashboardController
    at umbraco-backoffice-js.js.vc6e8bc0959901a75d8026fd6454b7729c35d534b:25:168
    at umbraco-backoffice-js.js.vc6e8bc0959901a75d8026fd6454b7729c35d534b:117:19
    at ea (umbraco-backoffice-js.js.vc6e8bc0959901a75d8026fd6454b7729c35d534b:99:20)
    at p (umbraco-backoffice-js.js.vc6e8bc0959901a75d8026fd6454b7729c35d534b:90:355)
    at g (umbraco-backoffice-js.js.vc6e8bc0959901a75d8026fd6454b7729c35d534b:84:186)
    at umbraco-backoffice-js.js.vc6e8bc0959901a75d8026fd6454b7729c35d534b:83:311
    at Object.link (umbraco-backoffice-js.js.vc6e8bc0959901a75d8026fd6454b7729c35d534b:321:432)
    at umbraco-backoffice-js.js.vc6e8bc0959901a75d8026fd6454b7729c35d534b:35:134
    at Ca (umbraco-backoffice-js.js.vc6e8bc0959901a75d8026fd6454b7729c35d534b:108:361)
    at p (umbraco-backoffice-js.js.vc6e8bc0959901a75d8026fd6454b7729c35d534b:92:340) '<div ng-include="property.view">'
    Some other Dashboards (such as the Cultiv.Hangfire one ) show up fine.
    Any ideas what might be causing this. I tried deleting the Smidge Cache folder, but it did not make a difference.
    Thanks in advance,
    Kap.
    Sep 20, 2024 @ 15:42
    Kap
    Setting the Debug :true flag in the appsettings.json file allowed the Dashboard to work. Unfortunately it is not a solution as I cannot leave Debug on for Production. Has anyone else come across this?
    Kap.
  • Kevin Jump 2343 posts 14891 karma points MVP 8x c-trib
    Sep 20, 2024 @ 16:20
    Kevin Jump
    What other packages do you have installed? when in production mode, Umbraco squishes all the JavaScript for all the packages together, it can often be something conflicting between two packages.
    if you have a full list of installed 3rd party things we might be able to work out where the clash is.
    Sep 25, 2024 @ 10:39
    Kap
    Hi Kevin,
    Thanks for the info. I will see if I can identify the misbehaving package. I think it might be an internal dashboard which is causing the issue.
    Kap.
    Nov 15, 2024 @ 19:39
    Kap
    Just found this post - which appears to solve the issue:
    Effectively just added
          "RuntimeMinification": {
        "useInMemoryCache": true,
        "CacheBuster": "AppDomain"
    to the Umbraco section of the appsettings.json file, and the dashboards work.
    EDIT: This didnt resolve the issue fully. I found that I had to move the items from /AppPlugin to /wwwroot/AppPlugin which appears to have resolved it - just in case anyone else has the same issue.
