Similar to the preview concept in Umbraco, the Delivery API allows for requesting unpublished content through its endpoints.
This is done by setting a Preview header to true in the API request.
Accessing unpublished versions of your content nodes requires authorization via an API key configured in appsettings.json file using the Umbraco:CMS:DeliveryApi:ApiKey configuration key. To obtain preview data, you must add the Api-Key request header containing the configured API key to the appropriate endpoints.
GET /umbraco/delivery/api/v2/content/item/11fb598b-5c51-4d1a-8f2e-0c7594361d15
Preview: true
Api-Key: my-api-key
Is the API key not applied using the Api-Key request header, the unpublished content will not be included in the JSON response.
How to include unpublished nodes whilst using Rest APIs
Hi All
Is there a a way to retrieve unpublished nodes using the following REST API?
/umbraco/rest/v1/content/searchi know we need to use the
InternalIndexto get unpublished nodes....but how do we do that using the API?Thanks in advance for any help
Hi James,
Take a look at the documentation regarding the Preview functionality under Concepts.
https://docs.umbraco.com/umbraco-cms/reference/content-delivery-api
Similar to the preview concept in Umbraco, the Delivery API allows for requesting unpublished content through its endpoints. This is done by setting a Preview header to true in the API request. Accessing unpublished versions of your content nodes requires authorization via an API key configured in appsettings.json file using the Umbraco:CMS:DeliveryApi:ApiKey configuration key. To obtain preview data, you must add the Api-Key request header containing the configured API key to the appropriate endpoints.
