I am trying to build my very first Umbraco project and everything worked great until I followed the "Member Registration and Login" tutorial from umbracos site.
After adding the Login page under Content suddenly all my pages show the following error.
The type or namespace name 'Home' could not be found (are you missing a using directive or an assembly reference?)
This is appointed to the top of my Master template with the line
var home = (Home)Model.Root();
I have zero clue as to where to look for the bug or why this would happen, so if anyone can point me to the right direction it would be immensely appreciated
Umbraco generates 'models' based on the Document Type of your schema to make it easy in your templates to write out the values of the properties in the Document Type.
So if you have a Document Type called Home, it will generate a model also called 'Home' that will contain all the properties of the Home Document Type.
Your line of code
says get me the content item at the root of this site and cast it to the type 'Home'
and as this is in your layout template this code is being executed on every page,
so what I think 'might have happened' in following the tutorial, is you have either renamed the 'Home' Document type or, as part of the tutorial there is something preventing Umbraco from generating all the models or you you've added the 'Login Page' directly under Content? - maybe now Model.Root() is the LoginPage and not the Home page but I think that would give a different error...
How to resolve this, depends a little on what you are using the 'home' variable for in the master template - but first thing would be to check that the Home document type is still called Home... and then make an update to your new Login Document type and have a look in the Umbraco logs to see if there has been an issue generating models generally...
Sudden Missing 'Home' type or namespace.
The type or namespace name 'Home' could not be found (are you missing a using directive or an assembly reference?)This is appointed to the top of my Master template with the line
var home = (Home)Model.Root();I have zero clue as to where to look for the bug or why this would happen, so if anyone can point me to the right direction it would be immensely appreciated
Hi Claus
Your line of code
Additionally depending on which 'modelsbuilder mode' you are running in: https://docs.umbraco.com/umbraco-cms/13.latest-lts/reference/templating/modelsbuilder/builder-modes you may need to rebuild your application to get the updated models.
regards
Marc
