  • npack 68 posts 378 karma points
    Oct 28, 2024 @ 20:07
    npack
    Changing Configuration From Code Instead of AppSettings.json?
    I want to change the Umbraco/CMS/Global/ReservedPaths configuration setting from inside my program.cs instead of doing it in appsettings.json.
    Why? I have so many reserved paths that the json is getting unwieldy
    "ReservedPaths": "~/path1,~/path2,~/path3",  /* but with longer paths and many more
    Does anybody know if this is possible? It seems like during startup in program.cs it would be a good opportunity.
    Oct 29, 2024 @ 15:12
    npack
    Which service am I to retrieve from GetRequiredService?
    There is a GlobalSettings configuration class for that config section but I must be doing things incorrectly since my runtime change doesn't seem to override the appsettings.json values.
    This is what DOESNT work:
            var globalSection = umbracoBuilder.Config.GetSection("Umbraco:CMS:Global").Get<GlobalSettings>();
            if (globalSection != null)
                globalSection.ReservedPaths = globalSection.ReservedPaths.Replace("somevalue", "someothervalue");
                umbracoBuilder.Config.GetSection("Umbraco:CMS:Global:ReservedPaths").Value = globalSection.ReservedPaths;
  • Kevin Jump 2348 posts 14896 karma points MVP 9x c-trib
    Oct 29, 2024 @ 19:44
    Kevin Jump
    You can use PostConfigure method in a composer to change the settings values (this is called when the site loads and if the file is changed, and the settings reloaded).
    e.g.
    public class MyReservePathComposer : IComposer
        public void Compose(IUmbracoBuilder builder)
            builder.Services.PostConfigure<GlobalSettings>(settings =>
                settings.ReservedPaths = "one, two, three";
    as a composer it will get wrapped into umbraco and called when the site starts.
    Oct 29, 2024 @ 20:31
    npack
    Thanks Kevin,
    I dropped in this composer class but its 'Compose' method didn't seem to get hit. I'm using Umbraco 14. I haven't used a composer before, but I thought that it would be found and registered automatically on startup. Is that correct?
