  • Bjarne Olesen 3 posts 73 karma points
    Oct 30, 2024 @ 12:45
    Bjarne Olesen
    Umbraco.Templates in Visual studio 2019 is not displayed
    Why can't I see Umbraco Templates in Visual studio 2019?
    I have installed Umbraco Templates but when I want to create a new project in visual studio 2019, it shows no templates.
    I have also tried restarting visual studio 2019 and windows 10 but to no avail. What am I doing wrong?enter image description here
    I have attached some screen dump.
    Please help me
    thanks in advance
  • Sebastiaan Janssen 5060 posts 15522 karma points MVP admin hq
    Oct 30, 2024 @ 14:12
    Sebastiaan Janssen
    I believe you need to be using VS2022 instead.
    Oct 30, 2024 @ 19:15
    Bjarne Olesen
    Can't it run or programmed under VS 2019?
    Oct 30, 2024 @ 21:21
    Sebastiaan Janssen
    VS2019 only supports up to .NET 5,for Umbraco 13 you need at least .NET 7 I believe. And for v14 you need .NET 8.
    I think that's why the templates don't show up in your VS, since it knows it can't build the Umbraco project.
    You can definitely install the .NET 8 SDK and install and run Umbraco from the command line, but it won't compile in VS2019.
    Nov 04, 2024 @ 12:07
    Bjarne Olesen
    Is there any other way to install Umbraco, so i can develop and compile it in vs studio 2019. Or should i go with an older version
