how to pass model values to partialview form surfacecontroller post action
I'm extending umbraco site using locally declared surfacecontrollers and forms. on submit form I have some server side validations and return to form with errors.
I'm rendering view using macro using code below,
Requirement - Enter email do a validation on controller and then load view with different form then step 2 enter rest of the details and submit again. how do I pass entered values back to form rather than passing empty model?
I tried returrn CurrentUmbracoPage() and rerturn RedirectToCurrentUmbracoPage() and TemData but failed to load values to input fields .
I can pass error using TempData but I cannot pass entered form values back.
any idea how to sort this ?
I recommend checking out this blog on creating multi-step forms using a SurfaceController. Although it’s an older post, it provides valuable insight into implementing multi-step forms in Umbraco and can help you understand the overall concept.
I'm extending umbraco site using locally declared surfacecontrollers and forms. on submit form I have some server side validations and return to form with errors. I'm rendering view using macro using code below,
I tried returrn CurrentUmbracoPage() and rerturn RedirectToCurrentUmbracoPage() and TemData but failed to load values to input fields . I can pass error using TempData but I cannot pass entered form values back. any idea how to sort this ?
Hi Pathini,
There is another in forum itself checkout this also - Multi-step-form-implementation
For enhanced UI transitions, you might consider using JavaScript plugins designed for multi-step forms. Here are some lightweight options:
