  • Peter 11 posts 81 karma points
    Nov 05, 2024 @ 17:19
    Peter
    Umbraco forms multi language
    Hi - it is possible to localise texts (eg. field captions) on a form by using the dictionary, and key names like "#FormFieldFirstname".
    This works fine when browsing the live site - showing the English, German, or French field captions for example.
    But when previewing the page/form, then only the English language texts are displayed. Changing the current language in the backoffice does not help.
    What am I doing wrong? The editors want to see the captions in the relevant language in the backoffice preview.
  • Yakov Lebski 594 posts 2350 karma points
    Nov 05, 2024 @ 18:08
    Yakov Lebski
    Sure, just add text with # at start #Name will use Name from tranlsations
    Nov 05, 2024 @ 18:21
    Peter
    Thanks - that is what I am doing. I am starting to think there is a lot of tailor-made code in this solution which is messing with the way Umbraco handles this. I will need to dig deeper.
  • Afreed 86 posts 383 karma points MVP
    Nov 08, 2024 @ 09:34
    Afreed
    I think you are having the same issue as in here
    Issue
    Nov 08, 2024 @ 09:55
    Peter
    Thanks - yes looks the same. So not actually only related to "forms" but to any document type.
    Note that it does work fine on the live site (ie the labels on the form change language), and also in the "preview" - for example with a url like "site/umbraco/preview/?id=1593&culture=da"; but it does not work when displaying the node in the backoffice (which would be a "nice to have" for the content editors).
    Nov 08, 2024 @ 10:06
    Afreed
    2
    Yes, it indeed is nice to have for a content editor, it would be addressed on the roadmap to v17. However, I’m not sure if it will be prioritized immediately.
