To clarify the usage and types for this.content?.images, you'll need to typecast it to either UmbMediaPickerPropertyValue or a custom type, as Umbraco's media picker typically returns an array of objects with mediaKey (GUIDs) rather than URLs. You'll fetch the URL using these GUIDs.
you need to retrieve the URL for each media key. In Umbraco, this can be done by using UmbImagingRepository, to fetch the media URLs based on the keys provided by the media picker.
here is the example for this:
import { html, customElement, LitElement, property, css, state } from '@umbraco-cms/backoffice/external/lit';
import { UmbElementMixin } from '@umbraco-cms/backoffice/element-api';
import { UmbImagingRepository } from '@umbraco-cms/backoffice/imaging'; // Import the repository
import type { UmbBlockDataType } from '@umbraco-cms/backoffice/block';
import type { UmbBlockEditorCustomViewElement } from '@umbraco-cms/backoffice/block-custom-view';
import type { UmbMediaPickerPropertyValue } from '@umbraco-cms/backoffice/media';
@customElement('example-block-custom-view')
export class ExampleBlockCustomView extends UmbElementMixin(LitElement) implements UmbBlockEditorCustomViewElement {
@property({ attribute: false })
content?: UmbBlockDataType;
@state()
logos: UmbMediaPickerPropertyValue[] = [];
@state()
logoUrls: Map<string, string> = new Map();
#imagingRepository = new UmbImagingRepository(this);
async updated(changedProperties: Map<string | number | symbol, unknown>) {
super.updated(changedProperties);
if (changedProperties.has('content') && this.content?.logo) {
this.logos = this.content.logo as UmbMediaPickerPropertyValue[];
await this.fetchLogoUrls();
async fetchLogoUrls() {
for (const logoItem of this.logos) {
if (logoItem.mediaKey && !this.logoUrls.has(logoItem.mediaKey)) {
const url = await this.resolveMediaUrl(logoItem.mediaKey);
if (url) {
this.logoUrls.set(logoItem.mediaKey, url);
this.requestUpdate(); // Trigger a re-render to update URLs
async resolveMediaUrl(mediaKey: string): Promise<string> {
const { data } = await this.#imagingRepository.requestThumbnailUrls([mediaKey], 300, 300);
return data?.[0]?.url ?? '';
override render() {
console.log(this.content);
return html`
<h5>My Custom View</h5>
<p>Headline: ${this.content}</p>
<div class="logo-container">
${this.logos.map((logoItem: UmbMediaPickerPropertyValue) => html`
<img src="${this.logoUrls.get(logoItem.mediaKey) || ''}" alt="Logo" />
static override styles = [
css`
:host {
display: block;
height: 100%;
box-sizing: border-box;
background-color: #dddddd;
border-radius: 9px;
padding: 12px;
export default ExampleBlockCustomView;
declare global {
interface HTMLElementTagNameMap {
'example-block-custom-view': ExampleBlockCustomView;
Umbraco 14, Custom view with web component for a media picker block
Hi, I have a block grid with an "image picker" block that has a property named "images," which is a multiple-image media picker.
I have created a custom view for the block, but I can only access the media keys and not the media URLs to display the images.
In this line
<img src="${image.key}">i don't want the key property but the url property that does not exist in that object. How can i get it?Thanks in advance
Hi Ivan,
Hope this helps
@afreed Yeh! I needed the UmbImagingRepository, thank you. Umbraco is in need of Web Components Libraries Documentation.
Yes, this will be added en route to Umbraco v17. Hopefully
