The issue I am having is that this worked fine in version 8 of Umbraco but now the LINQ statements are not working, they don't seem to access the model content unless using @model instead of inherit but Umbraco then breaks all over if you do that.
I'm a bit stuck as the other Model. references work just fine
IHtmlHelper not accepting model?
Here is the top part of the code:
To reiterate, this worked in V8 with almost the exact same code, now it doesn't in 13. Any help is appreciated!
