I started working with Umbraco 15 and implementing Block Grid backoffice view following this tutorial: https://docs.umbraco.com/umbraco-cms/tutorials/creating-custom-views-for-blocklist
But property:
@property({ attribute: false }) settings?: UmbBlockDataType;
Is always undefined.
This is my module:
import { html, customElement, LitElement, property } from '@umbraco-cms/backoffice/external/lit'; import { UmbElementMixin } from '@umbraco-cms/backoffice/element-api'; import type { UmbBlockEditorCustomViewElement } from '@umbraco-cms/backoffice/block-custom-view'; import { type UmbBlockDataType } from '@umbraco-cms/backoffice/block'; // UmbBlockDataType @customElement('button-component') export class ButtonBlockCustomView extends UmbElementMixin(LitElement) implements UmbBlockEditorCustomViewElement { @property({ attribute: false }) content?: UmbBlockDataType; @property({ attribute: false }) settings?: UmbBlockDataType; getSizeFromSettings(size:string) { if (!size || size.trim() === '') return ''; switch (size) { case 'large': return ' btn--lg'; case 'medium': return ' btn--md'; case 'small': return ' btn--sm'; default: return ''; } } override render() { debugger; const sizeClass = this.getSizeFromSettings(this.settings?.size as string); const link: {name: string}[] = this.content?.link as {name: string}[]; return html` <link rel="stylesheet" href="/assets/css/styles/allstyles.css" /> <a class="btn btn--primary ${sizeClass}"> ${link[0].name ? html`<span>${link[0].name}</span>` : ''} ${this.settings?.buttonArrow ? html` <svg xmlns="http://www.w3.org/2000/svg" width="24" height="24" fill="none"> <path fill="#1C2541" fill-rule="evenodd" d="M12.075 5.576a.6.6 0 0 0 0 .848l4.976 4.976H6a.6.6 0 1 0 0 1.2H17.05l-4.976 4.976a.6.6 0 0 0 .849.848l6-6a.6.6 0 0 0 0-.848l-6-6a.6.6 0 0 0-.849 0Z" clip-rule="evenodd" ></path> </svg> ` : ''} </a> `; } } export default ButtonBlockCustomView;
Umbraco Block Grid backoffice custom view the settings property is always undefined for Umbraco 15
But property:
This is my module:
