  • Paria 5 posts 25 karma points
    24 days ago
    Paria
    Accessing to BlockGrid contents for label
    I'm trying to show content value in the label of BlockGrid, I have tried a lot of ways but none are working, my config is like this: enter image description here
    I tried this in the label, but no result:
    {{HeadingComponent.Heading}}
    {{Content.HeadingComponent.Heading}}
    {{$Content.HeadingComponent.Heading}}
    {{Heading}}
    Any suggestions?
  • npack 68 posts 378 karma points
    24 days ago
    npack
    I think in v13 and earlier you have to use angularJs syntax. Here is a good blogpost about some common label syntax situations https://joe.gl/ombek/blog/umbraco-angularjs-filter-cheat-sheet/
    It looks like in your case you ought to try the word 'heading' in lower case.
    {{heading}} {{heading.length > 0 ? heading : "Heading"}}
  • Robert Runge 2 posts 72 karma points
    22 days ago
    Robert Runge
    In the screen shot shown above, the property name is “Test” and not “Heading”. Could that be the problem?
  • Afreed 86 posts 383 karma points
    21 days ago
    Afreed
    Yes, alias should be used inside {{}} (example : {{heading}})
