  • Genc Kastrati 90 posts 415 karma points
    Feb 17, 2025 @ 09:04
    Genc Kastrati
    Umbraco 13 - Web Application Project
    Hi all,
    I am currently working on the upgrade to V13, and for V8 I had a Visual Studio solution that made it possible to compile/prebuild the custom code into a DLL.
    I am wondering if same can be done for V13 because when I clone the Cloud project locally, the folder structure is different from before.enter image description here
    I am not sure how to approach this. Any suggestions welcome! Thank you, Genc
  • girish 23 posts 116 karma points
    Feb 18, 2025 @ 06:52
    girish
    Yes, you can still compile your custom code into a DLL for Umbraco 13—even with the Cloud project’s different folder structure.
    • Create a separate Class Library: Move your custom code into a new project that builds as a DLL.
    • Add the DLL reference to your main Umbraco project. Adjust build settings: Ensure the DLL is copied to the correct bin folder during the build.
    • Register your services in Startup.cs or Program.cs using dependency injection.
    • Alos please Check the Umbraco Cloud docs for any Cloud-specific changes or recommendations.
    please give it a try
    Feb 18, 2025 @ 15:52
    Genc Kastrati
    Thank you Girish! I will give this a try and report back!
