I have a site using 7.3.0 and I am trying to upgrade it to 7.4.1 and Im getting this issue:
Exception information:
Exception type: InvalidOperationException
Exception message: The pre-application start initialization method Install on type Umbraco.ModelsBuilder.Umbraco.LiveModelsProviderModule threw an exception with the following error message: Unrecognized attribute 'disableAlternativeTemplates'. Note that attribute names are case-sensitive. (D:\inetpub\wwwroot\roundsquare-uat714\httpdocs\config\umbracoSettings.config line 160).
at System.Web.Compilation.BuildManager.InvokePreStartInitMethodsCore(ICollection1 methods, Func1 setHostingEnvironmentCultures)
at System.Web.Compilation.BuildManager.InvokePreStartInitMethods(ICollection`1 methods)
at System.Web.Compilation.BuildManager.CallPreStartInitMethods(String preStartInitListPath, Boolean& isRefAssemblyLoaded)
at System.Web.Compilation.BuildManager.ExecutePreAppStart()
at System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters, PolicyLevel policyLevel, Exception appDomainCreationException)
at System.Configuration.BaseConfigurationRecord.EvaluateOne(String[] keys, SectionInput input, Boolean isTrusted, FactoryRecord factoryRecord, SectionRecord sectionRecord, Object parentResult)
at System.Configuration.BaseConfigurationRecord.Evaluate(FactoryRecord factoryRecord, SectionRecord sectionRecord, Object parentResult, Boolean getLkg, Boolean getRuntimeObject, Object& result, Object& resultRuntimeObject)
at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject)
at System.Configuration.BaseConfigurationRecord.GetSection(String configKey)
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at Umbraco.Core.Configuration.UmbracoConfig.<.cctor>b__0()
at System.Lazy1.CreateValue()
at System.Lazy1.LazyInitValue()
at Umbraco.ModelsBuilder.Umbraco.LiveModelsProviderModule.Install()
Upgrade to 7.4.1 issues
Hi, I have a site using 7.3.0 and I am trying to upgrade it to 7.4.1 and Im getting this issue:
Exception information: Exception type: InvalidOperationException Exception message: The pre-application start initialization method Install on type Umbraco.ModelsBuilder.Umbraco.LiveModelsProviderModule threw an exception with the following error message: Unrecognized attribute 'disableAlternativeTemplates'. Note that attribute names are case-sensitive. (D:\inetpub\wwwroot\roundsquare-uat714\httpdocs\config\umbracoSettings.config line 160). at System.Web.Compilation.BuildManager.InvokePreStartInitMethodsCore(ICollection
1 methods, Func1 setHostingEnvironmentCultures) at System.Web.Compilation.BuildManager.InvokePreStartInitMethods(ICollection`1 methods) at System.Web.Compilation.BuildManager.CallPreStartInitMethods(String preStartInitListPath, Boolean& isRefAssemblyLoaded) at System.Web.Compilation.BuildManager.ExecutePreAppStart() at System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters, PolicyLevel policyLevel, Exception appDomainCreationException)Unrecognized attribute 'disableAlternativeTemplates'. Note that attribute names are case-sensitive. (D:\inetpub\wwwroot\roundsquare-uat714\httpdocs\config\umbracoSettings.config line 160) at System.Configuration.BaseConfigurationRecord.EvaluateOne(String[] keys, SectionInput input, Boolean isTrusted, FactoryRecord factoryRecord, SectionRecord sectionRecord, Object parentResult) at System.Configuration.BaseConfigurationRecord.Evaluate(FactoryRecord factoryRecord, SectionRecord sectionRecord, Object parentResult, Boolean getLkg, Boolean getRuntimeObject, Object& result, Object& resultRuntimeObject) at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject) at System.Configuration.BaseConfigurationRecord.GetSection(String configKey) at System.Configuration.ConfigurationManager.GetSection(String sectionName) at Umbraco.Core.Configuration.UmbracoConfig.<.cctor>b__0() at System.Lazy
1.CreateValue() at System.Lazy1.LazyInitValue() at Umbraco.ModelsBuilder.Umbraco.LiveModelsProviderModule.Install()Any ideas?
Jon
