Why doesnt this code print "NewString" value? It prints the text only (as in the code itself) but not the value (in this case the destination once the , is stripped off)?
@foreach (var childPage in Model.Children.Where("Visible"))
<li>
<a href="@childPage.Url">@childPage.Name</a>
var myString = @childPage.Destination.ToString();
var NewString = myString.Split(',').Last();
New string is <span>NewString</span>
@* if the current page has any children, where the property umbracoNaviHide is not True *@
@if (childPage.Children.Where("Visible").Any())
@* Call our helper to display the children *@
@childPages(childPage.Children )
</li>
Try to move your variables before the li tag. I have not tested it but this is what I would type:
<li>
New string is <span>@NewString</span>
@childPages(childPage.Children)
</li>
Razor Syntax issue
Change this line of code with the of following:
I tried that and get the error
The name 'NewString' does not exist in the current context
Perhaps you answered your own question.
The code
@childPage.Destination.ToString()may instead be@childPage.Destination.Value.ToString()Or something along those lines.
