  • J 447 posts 864 karma points
    Mar 23, 2016 @ 11:42
    J
    Razor help to embed image
    I have the below code which is using Javascript and Razor. The below code is within the Javascript parameter which is working
    foreach (var childPage in Model.Children.Where("Visible"))
        var CustomerAndImage = @childPage.CustomerName + '<img src="' + @Model.MediaById(@childPage.image).umbracoFile +'" alt="Porcelain Factory of Vista Alegre" height="115" width="83">';
        <text>['@CustomerAndImage'],</text>
    I'm trying to embed an image to be part of the variable CustomerAndImage but whenever i add 'Too many characters in character literal"
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Mar 23, 2016 @ 11:50
    Dave Woestenborghs
    Hi J,
    This because you are single quotes. In c# (Razor) this can only contain one character. For full strings you need to surround it with double quotes :
        var CustomerAndImage = @childPage.CustomerName + "<img src=\"" + @Model.MediaById(@childPage.image).umbracoFile +"\" alt=\"Porcelain Factory of Vista Alegre\" height=\"115\" width="83">";
        <text>['@Description'],</text>
    Dave
    Mar 23, 2016 @ 12:06
    J
    Hi Dave - thanks
    I did that, added and an extra \ where it was missed off but instead of the img tag being embedded its just displaying the code as text? Any idea?
    Mar 23, 2016 @ 12:20
    Dave Woestenborghs
    Can you post your entire code. This is just a few lines. Can not see where it is going wrong
    Mar 23, 2016 @ 12:28
    J
    I've changed some of it whilst refactoring. Please see below
    @inherits umbraco.MacroEngines.DynamicNodeContext
    <script src="http://maps.googleapis.com/maps/api/js"></script>
    var MapLocations = [
    @if (Model.Children.Where("Visible").Any())
        var naviLevel = Model.Children.Where("Visible").First().Level;
                var LatLng = @childPage.LatLng;
                var Customer = @childPage.CustomerName;
                var Image = "<img src=\"" + @Model.MediaById(@childPage.image).umbracoFile + "\" alt=\"test\" height=\"115\" width=\"83\">";
                <text>['@Customer' + '@Image', @LatLng],</text>
    Mar 23, 2016 @ 12:44
    Dave Woestenborghs
    Hi J,
    Can you do this :
     <text>['@Customer' + '@Html.Raw(Image)', @LatLng],</text>
    Dave
