I've upgraded an Umbraco website from 6.x to 7.4.1
I swapped out the File Upload ("umbracoFile") property editor with an Image Cropper and added some crops, which, from what I can tell from reading forum posts, is the recommended practice.
Unfortunately, calling GetCropUrl(cropAlias) returns the original image, i.e. not the cropped version.
We have some 3,000 images in the media section.
Should the crops be working? Or is there something I'm missing?
I'm hoping I'm not going to be told that I need to go through each of the 3,000 images and re-save them all! :-)
Thanks guys. Unfortunately the log file reports the following for all images:
2016-03-28 14:29:10,864 [P12788/D9/T75] INFO Our.Umbraco.CropHealer.CropHealer - Skipping media property as no image has been uploaded yet (NodeId:12111 DocumentTypeAlias:Image, PropertyAlias:umbracoFile)
What I did was change go into CMS>Settings>Media Types. Clicked "Upload Image" property. Clicked the icon of the "File Upload" property type. In the popout, selected Image Cropper. Then Submit, Submit, Save.
GetCropUrl images not cropped
You need to go through each of the 3,000 images and re-save them all! :-)
Luckily, there's a package for that: https://our.umbraco.org/projects/collaboration/crop-healer-for-umbraco/
Hi Mark,
Perhaps you also need to make some adjustments for the Razor code that you use for getting the image crop.
Try to see this documentation. https://our.umbraco.org/documentation/getting-started/backoffice/property-editors/built-in-property-editors/image-cropper
Hope this helps,
/Dennis
Did I do something wrong?
