And the SendInternalEmail method roughly like this:
private void SendInternalEmail(MyModel model)
//NOTE: the GetPropertyValue throws a NullReferenceException when this method is run async!
//-even though the node is correctly found and the prop can be seen on it with a value
var node = Umbraco.TypedContent(model.NodeId);
string emailAddress = node.GetPropertyValue<string>("internalEmailAddress");
The umbraco logs show this (confidential code replaced with mycode):
2016-03-28 10:29:19,663 [P10052/D15/T471] ERROR <mycode> - Object reference not set to an instance of an object.
at Umbraco.Web.Templates.TemplateUtilities.ParseInternalLinks(String text, Boolean preview)
at Umbraco.Web.PropertyEditors.ValueConverters.TextStringValueConverter.ConvertDataToSource(PublishedPropertyType propertyType, Object source, Boolean preview)
at Umbraco.Web.PublishedCache.XmlPublishedCache.XmlPublishedProperty.<.ctor>b__0()
at System.Lazy`1.CreateValue()
at System.Lazy`1.LazyInitValue()
at Umbraco.Web.PublishedCache.XmlPublishedCache.XmlPublishedProperty.<.ctor>b__1()
at Umbraco.Web.PublishedPropertyExtension.GetValue[T](IPublishedProperty property, Boolean withDefaultValue, T defaultValue)
at Umbraco.Web.PublishedContentExtensions.GetPropertyValue[T](IPublishedContent content, String alias)
at <mycode>.SendInternalEmail(MyModel model) in C:\Development\<mycode>:line 71
Any one seen this? Am I missing something? Im using umbraco v7.4.
I am not sure if it is related but since moving to Umbraco 7.4 I have experience a few similar problems. My problems have mainly been running umbraco saves within the background tasks. The gets I haven't really noticed any problems but I haven't looked at the logs in a while.
Basically the problems I've been having is the context is missing and when I attempt to update / save something into umbraco within a background task it fails.
I googled around and found an hack to fake the context.
//fake the context to get around an error
//exception details: Value cannot be null.Parameter name: httpContext
HttpContext.Current = new HttpContext(new HttpRequest(null, "https://www.google.com", null), new HttpResponse(null));
I am not sure if your issues are caused by the same thing but I have a feeling they might be. Try adding this block of code before dealing with the Umbraco gets and sets. See if it helps.
Hey, I know this is an old post but I ran into a similar issue and was able to resolve it. I passed reference to the the current Umbraco context to the async function and then in that function I got the property like so:
Task.Run with GetPropertyValue gives NullRefException
Hi lovely umbraco community :) I wonder if anyone has seen this / if its by design:
I have a NullReferenceException being generated when I try to use GetPropertyValue within a method called from Task.Run, within a surface controller.
The Task.Run part looks like this:
mycode):Any one seen this? Am I missing something? Im using umbraco v7.4.
tia Ian
Kind Regards
David
Have you managed to fix this problem?
I'm currently experiencing the exact same problem. Running a task with a GetPropertyValue call in it returns a NullReferenceException
I've tried adding the fake HttpContext on a few places, but no luck so far.
Kind regards,
Mark
Hi Mark
no I didnt fix it, I just worked around it by getting all the properties I needed before the Task.Run call and just passing them in.
Ian
Hope this helps somebody.
Legend! Works fine any idea if the value is an Id or Udi, how I can access that entity as well?
