  • Chris Clancy 65 posts 134 karma points
    Mar 30, 2016 @ 13:19
    Chris Clancy
    CMS Import links and iframe issue Umbraco v7.4
    I have been successfully using CMS Import which has worked great so far and will save us huge amounts of time during content migration.
    I do have an issue with my data import. The data file is CSV and everything in there looks good - If I dump the data for an article it straight into a HTML page it is all formatted correctly (I changed some characters to HTML codes during SQL export). When CSV data is imported into Body Text fields (RTE) the links are a little scrambled.
    Standard links are stripped of the "href=" so instead of:
    <a href="http://www.umbraco.com">Umbraco</a>
    I get:
    <a>Umbraco</a>
    And for Iframes it is changing from:
    <iframe width="560" height="315" src="https://www.youtube.com/embed/WU-1PR0ehSM" frameborder="0" allowfullscreen="allowfullscreen"></iframe>
    to:
    <iframe 560="" 315="" https:="" www="" youtube="" com="" embed="" wu-1pr0ehsm="" 0="" allowfullscreen="" frameborder="" height="" width=""></iframe>
    Any ideas what might be going on here?
    BTW this import was done using the demo version of CMS Import - we now have a licence but I have not yet used the full version.
    Mar 31, 2016 @ 14:16
    Chris Clancy
    Has anyone else noticed this behaviour? Have other CMSImport users managed to get their links and iframes across successfully? I'd love to hear if you have!!
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Mar 31, 2016 @ 14:50
    Richard Soeteman
    Hi Chris,
    didn't receive a notification about this issue. But I think your issue is related to the Rich text editor configuration where IFrame's are stripped. You can tweak the config of Rich Text editor settings in TinyMCESettings.config file.
    Hope this helps,
    Richard
    Mar 31, 2016 @ 15:09
    Chris Clancy
    Hi Richard,
    Yes we did think that could be the issue. I'm looking into it now and I'll post my findings on here when I have investigated.
    Chris
    Apr 12, 2016 @ 13:29
    Chris Clancy
    Ok so it looks like this has been resolved now. First I decided to import my rich text data into a plain old text area to see how the data looked.
    From there I could see that ther links were not jumbled but had double quotes around existing double quotes.
    E.g:
    <a href=""http://www.google.com"">Google</a>
    So I then used the Text Indicator option in the CMS Import setup and chose the double quote option. The data now comes through perfectly.
