  • pnr 131 posts 226 karma points
    Apr 04, 2016 @ 13:37
    pnr
    Same node several places
    Is it somehow possible in Umbraco to create a node under one parent node, and then show the same node under other parent nodes?
    Parent 1 -> Sub 1 Node Parent 2 -> Sub 1 Node
    “Sub 1 Node” is the same node, just showing under different parentnodes.
    Thanks very much in advance.
  • Dennis Adolfi 1082 posts 6450 karma points MVP 6x c-trib
    Apr 04, 2016 @ 14:20
    Dennis Adolfi
    I dont think that a node can exist under several parents without beeing two separate nodes.
    What you can do to fix what you want is to create a empty node (or copy Sub 1 ) to Parent 2 and use the property UmbracoInternalRedirectId with a contentpicker, and for that empty node select Sub 1. That way Sub 1 under Parent 2 will redirect to Sub 1 under Parent 1.
    Hope this helped.
    Apr 04, 2016 @ 17:51
    pnr
    Thanks very much for your reply :-)
    Apr 04, 2016 @ 19:15
    Dennis Adolfi
    Happy to help. Did it work in your case?
  • Nicholas Westby 2054 posts 7104 karma points c-trib
    Apr 04, 2016 @ 20:08
    Nicholas Westby
    Yes, it is possible. You can implement a content finder that can tell Umbraco what content node to use for any given URL: https://our.umbraco.org/documentation/reference/routing/request-pipeline/icontentfinder
    Here's an example of one I implemented (for a different purpose): https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/64766-IIS-Rewrite-or-ContentFinder-UrlSegments#comment-243877
