I'm running an Umbraco v. 7.4.1 site which uses the member section for secured pages. By default, the members have five attempts of a successful login, else they're being locked out. I expect this is the default ASP.NET behavior.
Is there a way to prevent this lock out somehow? I've tried to set the following attribute on the membership provider in the config file: maxInvalidPasswordAttempts="999", but members are still being locked out after five attempts.
I have a Umbraco 7.4.1 and added maxInvalidPasswordAttempts="999" to the provider and it works just fine. I didn't try to login 999 times thou. Do you have custom provider or is everything pretty much default?
Preventing member lock out
Hi all,
maxInvalidPasswordAttempts="999", but members are still being locked out after five attempts.Any help/hint is greatly appreciated :-)
Thanks in advance.
Bo
My working config here below:
Hi Nathalie,
Thanks a lot for your reply.
It's strange, I tested it yesterday where it locked my member after 5 invalid attempts. Today it works as it should :-D
So, you're right: the
maxInvalidPasswordAttemptsattribute does indeed to it's job.Thanks again.
