  • Darren Wilson 238 posts 646 karma points
    Apr 07, 2016 @ 10:24
    Darren Wilson
    Search Problems (ezsearch)
    Hi Folks,
    I'm having a couple of issues on a site I'm using the ezsearch package:
    1. If a user search contains a question mark no results are shown - is there a way of modifying the Macro to ignore special characters (?,' etc)?
    2. Search results are sometimes erratic. If a user searches for: 'what fees can be claimed for stoma' they get no results. If they use 'what fees can be claimed stoma' the get a hit, it would appear the word 'for' is stopping the search. However, in another search if the word 'for' is included it displays results. I've checked the examine layer internal index and external search and both give out a result when searching for 'what fees can be claimed for stoma'.
    I'm a bit confused by this - will I need to rebuild the examine index, or is this something to do with restrictions within ez search? I've been at this for hours so a point in the right direction will be a huge help - thank you in advance lovely Umbraco people!
    Darren
    PS. Here's the site url: http://faqs.cps.scot/
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Apr 07, 2016 @ 12:34
    Steve Morgan
    Hi Darren,
    I've had these issues. I some changes to the Macro view file - I think there are also some client bespoke changes in so I can't just post the code.
    I'll try and diff the changes and see if I can pull out the fixes for you.
    Steve
    Apr 07, 2016 @ 13:05
    Steve Morgan
    Can you please try replacing the /Views/MacroPartials/ezSearch.cshtml file with this:
    The main changes are to add a searchTermsToSkip and updating the cleanseSearchTerm helper to stop chars like [ ] { } throwing exceptions.
    I've actually wrapped the entire thing with a try catch block that just renders empty search results instead of throwing an exception if you want that?
    @using System.Globalization
    @using System.Text
    @using System.Text.RegularExpressions
    @using Examine
    @using Umbraco.Core.Logging
    @using Umbraco.Web.Models
        int parsedInt;
        string[] searchTermsToSkip = { "for" };
        // Parse querystring / macro parameter
        var model = new SearchViewModel
            SearchTerm = CleanseSearchTerm(("" + Request["q"]).ToLower(CultureInfo.InvariantCulture)),
            CurrentPage = int.TryParse(Request["p"], out parsedInt) ? parsedInt : 1,
            PageSize = GetMacroParam(Model, "pageSize", s => int.Parse(s), 10),
            RootContentNodeId = GetMacroParam(Model, "rootContentNodeId", s => int.Parse(s), -1),
            RootMediaNodeId = GetMacroParam(Model, "rootMediaNodeId", s => int.Parse(s), -1),
            IndexType = GetMacroParam(Model, "indexType", s => s.ToLower(CultureInfo.InvariantCulture), ""),
            SearchFields = GetMacroParam(Model, "searchFields", s => SplitToList(s), new List<string> { "nodeName", "metaTitle", "metaDescription", "metaKeywords", "bodyText" }),
            PreviewFields = GetMacroParam(Model, "previewFields", s => SplitToList(s), new List<string> { "bodyText" }),
            PreviewLength = GetMacroParam(Model, "previewLength", s => int.Parse(s), 250),
            HideFromSearchField = GetMacroParam(Model, "hideFromSearchField", "umbracoNaviHide"),
            SearchFormLocation = GetMacroParam(Model, "searchFormLocation", s => s.ToLower(), "bottom")
        // Validate values
        if (model.IndexType != UmbracoExamine.IndexTypes.Content &&
            model.IndexType != UmbracoExamine.IndexTypes.Media)
            model.IndexType = "";
        if (model.SearchFormLocation != "top"
            && model.SearchFormLocation != "bottom"
            && model.SearchFormLocation != "both"
            && model.SearchFormLocation != "none")
            model.SearchFormLocation = "bottom";
        // Comment the next if statement out if you want a root
        // node id of -1 to search content across all sites
        // and not just the current site.
        if (model.RootContentNodeId <= 0)
            model.RootContentNodeId = Model.Content.AncestorOrSelf(1).Id;
        // If searching on umbracoFile, also search on umbracoFileName
        if (model.SearchFields.Contains("umbracoFile") && !model.SearchFields.Contains("umbracoFileName"))
            model.SearchFields.Add("umbracoFileName");
        // Check the search term isn't empty
        if(!string.IsNullOrWhiteSpace(model.SearchTerm))
            // Tokenize the search term
            model.SearchTerms = Tokenize(model.SearchTerm);
            // Perform the search
            var searcher = ExamineManager.Instance.SearchProviderCollection["ExternalSearcher"];
            var criteria = searcher.CreateSearchCriteria();
            var query = new StringBuilder();
            query.AppendFormat("-{0}:1 ", model.HideFromSearchField);
            // Set search path
            var contentPathFilter = model.RootContentNodeId > 0
                ? string.Format("__IndexType:{0} +searchPath:{1} -template:0", UmbracoExamine.IndexTypes.Content, model.RootContentNodeId)
                : string.Format("__IndexType:{0} -template:0", UmbracoExamine.IndexTypes.Content);
            var mediaPathFilter = model.RootMediaNodeId > 0
                ? string.Format("__IndexType:{0} +searchPath:{1}", UmbracoExamine.IndexTypes.Media, model.RootMediaNodeId)
                : string.Format("__IndexType:{0}", UmbracoExamine.IndexTypes.Media);
            switch (model.IndexType)
                case UmbracoExamine.IndexTypes.Content:
                    query.AppendFormat("+({0}) ", contentPathFilter);
                    break;
                case UmbracoExamine.IndexTypes.Media:
                    query.AppendFormat("+({0}) ", mediaPathFilter);
                    break;
                default:
                    query.AppendFormat("+(({0}) ({1})) ", contentPathFilter, mediaPathFilter);
                    break;
            // Ensure page contains all search terms in some way
            foreach (var term in model.SearchTerms)
                if(!searchTermsToSkip.Contains(term))
                    var groupedOr = new StringBuilder();
                    foreach (var searchField in model.SearchFields)
                        groupedOr.AppendFormat("{0}:{1}* ", searchField, term);
                    query.Append("+(" + groupedOr.ToString() + ") ");
            // Rank content based on positon of search terms in fields
            for (var i = 0; i < model.SearchFields.Count; i++)
                    query.AppendFormat("{0}:{1}*^{2} ", model.SearchFields[i], term, model.SearchFields.Count - i);
            var criteria2 = criteria.RawQuery(query.ToString());
            var results = searcher.Search(criteria2)
               .Where(x => (
                    !Umbraco.IsProtected(int.Parse(x.Fields["id"]), x.Fields["path"]) ||
                        Umbraco.IsProtected(int.Parse(x.Fields["id"]), x.Fields["path"]) &&
                        Umbraco.MemberHasAccess(int.Parse(x.Fields["id"]), x.Fields["path"])
                        (x.Fields["__IndexType"] == UmbracoExamine.IndexTypes.Content && Umbraco.TypedContent(int.Parse(x.Fields["id"])) != null) ||
                        (x.Fields["__IndexType"] == UmbracoExamine.IndexTypes.Media && Umbraco.TypedMedia(int.Parse(x.Fields["id"])) != null)
                .ToList();
            model.AllResults = results;
            model.TotalResults = results.Count;
            model.TotalPages = (int)Math.Ceiling((decimal)model.TotalResults / model.PageSize);
            model.CurrentPage = Math.Max(1, Math.Min(model.TotalPages, model.CurrentPage));
            // Page the results
            model.PagedResults = model.AllResults.Skip(model.PageSize * (model.CurrentPage - 1)).Take(model.PageSize);
            LogHelper.Debug<string>("[ezSearch] Searching Lucene with the following query: " + query.ToString());
            if (!model.PagedResults.Any())
                // No results found, so render no results view
                if(model.SearchFormLocation != "none")
                    @RenderForm(model)
                @RenderNoResults(model)
            else
                // Render out the results
                if (model.SearchFormLocation == "top" || model.SearchFormLocation == "both")
                    @RenderForm(model)
                @RenderSummary(model)
                @RenderResultsRange(model)
                @RenderResults(model)
                if(model.TotalPages > 1)
                    @RenderPager(model)
                if (model.SearchFormLocation == "bottom" || model.SearchFormLocation == "both")
                    @RenderForm(model)
        else
            // Empty search term so just render the form
                @RenderForm(model)
     Render Functions
    @helper RenderForm(SearchViewModel model)
        <form action="" method="GET" class="ezsearch-form">
            <input type="text" name="q" placeholder="@(GetDictionaryValue("[ezSearch] Search", "Search"))" value="@(model.SearchTerm)" />
            <input type="submit" value="@(GetDictionaryValue("[ezSearch] Search", "Search"))" />
        </form>
    @helper RenderSummary(SearchViewModel model)
        <div class="ezsearch-summary">
            <p>@FormatHtml(GetDictionaryValue("[ezSearch] Summary", "Your search for <strong>\"{0}\"</strong> matched <strong>{1}</strong> page(s)."), model.SearchTerm, model.TotalResults)</p>
    @helper RenderResultsRange(SearchViewModel model)
        var startRecord = ((model.CurrentPage - 1)*model.PageSize) + 1;
        var endRecord = Math.Min(model.TotalResults, (startRecord - 1) + model.PageSize);
        <div class="ezsearch-result-count">
            <p>@FormatHtml(GetDictionaryValue("[ezSearch] Results Range", "Showing results <strong>{0}</strong> to <strong>{1}</strong>."), startRecord, endRecord)</p>
    @helper RenderResults(SearchViewModel model)
        <div class="ezsearch-results">
            @foreach (var result in model.PagedResults)
                switch (result.Fields["__IndexType"])
                        var contentItem = Umbraco.TypedContent(result.Fields["id"]);
                        @RenderContentResult(model, contentItem)
                        break;
                        var mediaItem = Umbraco.TypedMedia(result.Fields["id"]);
                        @RenderMediaResult(model, mediaItem)
                        break;
    @helper RenderContentResult(SearchViewModel model, IPublishedContent result)
        <div class="ezsearch-result">
            <h2><a href="@result.Url">@result.Name</a></h2>
            @foreach (var field in model.PreviewFields.Where(field => result.HasValue(field)))
                <p>@Highlight(Truncate(Umbraco.StripHtml(result.GetPropertyValue(field).ToString()), model.PreviewLength), model.SearchTerms)</p>
                break;
    @helper RenderMediaResult(SearchViewModel model, IPublishedContent result)
            <h2><a href="@(result.GetPropertyValue<string>("umbracoFile"))" class="@(result.GetPropertyValue<string>("umbracoExtension"))">@result.Name</a></h2>
                break;
    @helper RenderPager(SearchViewModel model)
        <div class="ezsearch-pager">
            <p>
                @if (model.CurrentPage > 1) {
                    <a class="prev" href="?q=@(model.SearchTerm)&p=@(model.CurrentPage-1)">@(GetDictionaryValue("[ezSearch] Previous", "Previous"))</a>
                } else {
                    <span class="prev">@(GetDictionaryValue("[ezSearch] Previous", "Previous"))</span>
                @for (var i = 1; i <= model.TotalPages; i++)
                    if(i == model.CurrentPage) {
                        <span class="page">@i</span>
                    } else {
                        <a class="page" href="?q=@(model.SearchTerm)&p=@(i)">@i</a>
                @if (model.CurrentPage < model.TotalPages) {
                    <a class="next" href="?q=@(model.SearchTerm)&p=@(model.CurrentPage + 1)">@(GetDictionaryValue("[ezSearch] Next", "Next"))</a>
                } else {
                    <span class="next">@(GetDictionaryValue("[ezSearch] Next", "Next"))</span>
            </p>
    @helper RenderNoResults(SearchViewModel model)
        <div class="ezsearch-no-results">
            <p>@FormatHtml(GetDictionaryValue("[ezSearch] No Results", "No results found for search term <strong>{0}</strong>."), model.SearchTerm)</p>
    @functions
        //  Helper Functions
        // Cleanse the search term
        public string CleanseSearchTerm(string input)
            string sanitizedStr = input.Trim().Replace("[", "")
                                          .Replace("]", "")
                                          .Replace("{", "")
                                          .Replace("}", "")
                                          .Replace("(", "")
                                          .Replace(")", "")
                                          .Replace("!", "")
                                          .Replace("^", "");
            // * at start of str throws excep. but valid elsewhere - quick and dirty .. needs regexp
            if (sanitizedStr.Length > 0 && sanitizedStr[0] == '*')
                sanitizedStr = sanitizedStr.Replace("*", "");
            return Umbraco.StripHtml(sanitizedStr).ToString();
        // Splits a string on space, except where enclosed in quotes
        public IEnumerable<string> Tokenize(string input)
            return Regex.Matches(input, @"[\""].+?[\""]|[^ ]+")
                .Cast<Match>()
                .Select(m => m.Value.Trim('\"'))
                .ToList();
        // Highlights all occurances of the search terms in a body of text
        public IHtmlString Highlight(IHtmlString input, IEnumerable<string> searchTerms)
            return Highlight(input.ToString(), searchTerms);
        public IHtmlString Highlight(string input, IEnumerable<string> searchTerms)
            input = HttpUtility.HtmlDecode(input);
            foreach (var searchTerm in searchTerms)
                input = Regex.Replace(input, Regex.Escape(searchTerm), @"<strong>$0</strong>", RegexOptions.IgnoreCase);
            return new HtmlString(input);
        // Formats a string and returns as HTML
        public IHtmlString FormatHtml(string input, params object[] args)
            return Html.Raw(string.Format(input, args));
        // Gets a dictionary value with a fallback
        public string GetDictionaryValue(string key, string fallback)
            var value = Umbraco.GetDictionaryValue(key);
            return !string.IsNullOrEmpty(value)
                ? value
                : fallback;
        // Truncates a string on word breaks
        public string Truncate(IHtmlString input, int maxLength)
            return Truncate(input.ToString(), maxLength);
        public string Truncate(string input, int maxLength)
            var truncated = Umbraco.Truncate(input, maxLength, true).ToString();
            if (truncated.EndsWith("&hellip;"))
                var lastSpaceIndex = truncated.LastIndexOf(' ');
                if(lastSpaceIndex > 0)
                    truncated = truncated.Substring(0, lastSpaceIndex) + "&hellip;";
            return truncated;
        // Gets a macro parameter in a safe manner with fallback
        public string GetMacroParam(PartialViewMacroModel model, string key, string fallback)
            return GetMacroParam(model, key, s => s, fallback);
        public TType GetMacroParam<TType>(PartialViewMacroModel model, string key, Func<string, TType> convert, TType fallback)
            if(!model.MacroParameters.ContainsKey(key))
                return fallback;
            var value = model.MacroParameters[key];
            if(value == null || value.ToString().Trim() == "")
                return fallback;
            try
                return convert(value.ToString());
            catch (Exception)
                return fallback;
        // Splits a coma seperated string into a list
        public IList<string> SplitToList(string input)
            return input.Split(',')
                .Select(f => f.Trim())
                .Where(f => !string.IsNullOrEmpty(f))
                .ToList();
        //  Helper Classes
        public class SearchViewModel
            // Query Parameters
            public string SearchTerm { get; set; }
            public IEnumerable<string> SearchTerms { get; set; }
            public int CurrentPage { get; set; }
            // Options
            public int RootContentNodeId { get; set; }
            public int RootMediaNodeId { get; set; }
            public string IndexType { get; set; }
            public IList<string> SearchFields { get; set; }
            public IList<string> PreviewFields { get; set; }
            public int PreviewLength { get; set; }
            public int PageSize { get; set; }
            public string HideFromSearchField { get; set; }
            public string SearchFormLocation { get; set; }
            // Results
            public int TotalResults { get; set; }
            public int TotalPages { get; set; }
            public IEnumerable<SearchResult> AllResults { get; set; }
            public IEnumerable<SearchResult> PagedResults { get; set; }
    Apr 07, 2016 @ 13:11
    Steve Morgan
    I've just added this as a pull request to Matt Braisford's code. https://github.com/mattbrailsford/ezSearch
    Apr 07, 2016 @ 13:48
    Darren Wilson
    Hi Steve,
    Thanks for getting back to me - I'll give this a try.
    Darren
    Apr 07, 2016 @ 14:00
    Darren Wilson
    Hi Steve,
    If I wanted to skip a question mark, could I add this?
    int parsedInt;
    string[] searchTermsToSkip = { "?" };
    Cheers Darren
    Apr 07, 2016 @ 14:05
    Steve Morgan
    I'd add it to the replace list on the CleanseSearchTerm helper function at line 306 so it's stripped instead as I think the terms requires spaces around it.
                                      .Replace("]", "")
                                      .Replace("{", "")
                                      .Replace("}", "")
                                      .Replace("(", "")
                                      .Replace(")", "")
                                      .Replace("!", "")
                                      .Replace("?", "")
                                      .Replace("^", "");
    Apr 07, 2016 @ 14:20
    Darren Wilson
    This is great thanks - can I expand that list search terms to include other words like 'the', 'and'...?
    This search returns the correct entry:
    'forgotten login details for cps website how reset'
    This returns nothings:
    'I've forgotten my login details for the CPS website, how do I reset them'
    So I'd need to add the following... Ive, my, the, do, I
    Cheers Darren
    Apr 07, 2016 @ 14:29
    Darren Wilson
    I think I understand what happening here - it's not searching for the node title - is there any reason for this do you think?
    @Umbraco.RenderMacro("ezSearch", new {
         rootContentNodeId="1083" ,
      rootMediaNodeId="-1" ,
      indexType="CONTENT" ,
      searchFields="nodeName,answer" ,
      previewFields="nodeName,answer" ,
      previewLength="255" ,
      pageSize="10" ,
      hideFromSearchField="" ,
      searchFormLocation="TOP" })
    Apr 07, 2016 @ 14:30
    Steve Morgan
    Yup I'm guessing (but don't have the time to check either ezSearch or Lucene doesn't like small search words).
    But change line 13 (ish) to:
        string[] searchTermsToSkip = { "for", "Ive", "I've", "my", "the", "do", "I"  };
    Thinking on it you should probably change line 99 to:
                if (!searchTermsToSkip.Contains(term.ToUpper()))
    and make those:
        string[] searchTermsToSkip = { "FOR", "IVE", "I'VE", "MY", "THE", "DO", "I"  };
    Apr 07, 2016 @ 14:42
    Darren Wilson
    Brilliant! Thanks Steve!
    I'll implement this code.
    Darren
    Apr 07, 2016 @ 14:52
    Steve Morgan
    Sorry - posting at the same time as you.
    Do you mean the node name or do you have a field in your doc type called "Node Title" - if so find the alias (which is usually the name minus the spaces with a lowercase first letter - e.g. "nodeTitle") and add it to those search fields.
    I'd imagine it's more likely to be called "Page Title" - therefore add "pageTitle".
