I could use a little help solving this one.
For some reason - whenever I disable debugging in web.config, allowing the CDF to initialize, the paths for plugins in TinyMCE become faulty.
They look like this:
http://localhost:52099//plugins/newsletterstudio/plugin.js
http://localhost:52099//plugins/anchor/plugin.js
When they should look like this:
http://localhost:52099/umbraco/lib/tinymce/plugins/newsletterstudio/plugin.js
http://localhost:52099/umbraco/lib/tinymce/plugins/anchor/plugin.js
I've cleared caches, deleted the CDF folder, and incremented the CDF version, but it has no effect.
Any idea what's going on?
TinyMCE missing parts of plugin paths when CDF is enabled
http://localhost:52099//plugins/newsletterstudio/plugin.jshttp://localhost:52099//plugins/anchor/plugin.jsWhen they should look like this:
http://localhost:52099/umbraco/lib/tinymce/plugins/newsletterstudio/plugin.jshttp://localhost:52099/umbraco/lib/tinymce/plugins/anchor/plugin.jsI've cleared caches, deleted the CDF folder, and incremented the CDF version, but it has no effect.
