Hi! I have a question. I need to list the children with the "Active == true" property from a custom controller and from the .cshtml
Controller
public class PollsController : SurfaceController
private List<Theme> ThemeList()
var themePageList = Umbraco.Content(CurrentPage.Id).Children.Where("¿¿¿???");
var themeList = new List<Theme>();
foreach (var currentTheme in themePageList)
themeList.Add(
new Theme
ID = currentTheme.Id,
Title = currentTheme.Name,
return themeList;
public ActionResult RenderPoll()
var viewModel = new PollViewModel
Themes = ThemeList()
return PartialView("~/Views/Partials/_Polls.cshtml", viewModel);
And if to not filter on the controller, as I do to filter the view?
First of all, I would recommend using Umbraco.TypedContent rather than Umbraco.Content. This will ensure you are not using dynamic syntax, which will ensure you have intellisense. Here's an example:
var themePageList = Umbraco.TypedContent(CurrentPage.Id).Children.Where(x => x.GetPropertyValue<bool>("active"));
Actually, you can simplify that further:
var themePageList = CurrentPage.Children.Where(x => x.GetPropertyValue<bool>("active"));
This assumes you have a boolean property on your content nodes called "Active" (with an alias of active).
Filter children with a custom property
Controller
CSHTML
Umbraco content
Thx!!!
You may need to add a reference to
Umbraco.Webnamespace in your controller.Thx for you help, but Visual sayme "Cannot resolve symbol 'GetPropertyValue'".
Umbraco.TypedContentrather thanUmbraco.Content. This will ensure you are not using dynamic syntax, which will ensure you have intellisense. Here's an example:Actually, you can simplify that further:
active).Thx! but, no :( :( :( i try with:
Visual continues: "Cannot resolve symbol 'GetPropertyValue'"
You need to add this namespace to get access to that extension method:
By the way, you can use intellisense in Visual Studio 2015 to figure out which namespace you need for things that don't appear to exist:
Yes of course. i add Umbraco.web
That's weird. What version of Umbraco do you have? What happens when you type this:
What if you change your using statement to this:
Hi Gonzalo
Does it make any difference if you use the method
.Children()instead of the property.Children?Like in this example: http://umbracodevelopers.sdesign1dev.co.uk/2014/9/3/json-surface-controller/
/Bjarne
¬¬ ¬¬ ¬¬ Just missing using System.Linq; Resharper or VS nor solved that, it was by chance. Thank you for your support. !!!
