  • Ferdy Hoefakker 214 posts 248 karma points
    Apr 20, 2016 @ 13:14
    Ferdy Hoefakker
    Unpublish at not working (V7.2.8)
    Hey,
    Been trying to get the unpublish at function to work in a 7.2.8 install, but nothing I tried is working. I'm not getting any errors, it simply seems to not fire at all.
    Anything I could be missing in terms of hidden settings somewhere? Or is this a bug?
    -Ferdy
    Apr 20, 2016 @ 13:31
    Alex Skrypnyk
    Hi Ferdy,
    We have the same issue with Umbraco 7.4.3
    Looks like bug, is it working after Save and Publish button?
    Alex
    Apr 26, 2016 @ 08:03
    Ferdy Hoefakker
    Hi Alex,
    No, the function is not working at all. The logs show no sign of the event firing.
    -Ferdy
    Apr 26, 2016 @ 08:25
    Alex Skrypnyk
    Hi Ferdy,
    Yes, I can confirm, it's not working.
    There is bug - http://issues.umbraco.org/issue/U4-5562
    -Alex
  • Naveed Ali 161 posts 426 karma points
    Apr 28, 2016 @ 12:50
    Naveed Ali
    Hi all,
    The issue may be because you press "save and publish" after inputting a unpublish date..you need to just press "save".. this is what has been working for me..
    Pressing "save and publish" will remove the date in the unpublish date which is not what you want.
    Nav
    Apr 28, 2016 @ 13:14
    Alex Skrypnyk
    Hi Naveed,
    Do you think it should not work when press Save and Publish ?
    Apr 28, 2016 @ 13:19
    Naveed Ali
    Hi Alex,
    not sure if it should... but it doesn't from what I learnt..
    If I enter an unpublish date and press "save" the page successfully unpublishes at the date and time..
    If I press " save and publish" it does not work.
    Apr 28, 2016 @ 13:22
    Alex Skrypnyk
    Yes, the same behavior we have.
  • pnr 131 posts 226 karma points
    Jul 06, 2016 @ 12:05
    pnr
    We are having the same problem in Umbraco 7.2.8
    What is the conclusion of this problem, is it a bug or a "feature"? Umbraco can't reproceduce the problem....
    http://issues.umbraco.org/issue/U4-5204
