  • Tor Erik Skogen 31 posts 61 karma points
    Apr 26, 2016 @ 07:07
    Tor Erik Skogen
    Best e-com solution for max 10 products
    Hi Is there anybody out there who can recommended a lightweight e-commerce for maximum 10 product? Or maybe a package with some order, products e.x. I have a excisting site so it would be nice if i can integrated in this :) Tnx
    -Tor
    Apr 26, 2016 @ 08:51
    Hi Tor
    Unfortunately I have not tried any of the available shops for Umbraco myself but since you mention you currently have max 10 products then I guess it might be worth taking a further look at uWebshop - https://our.umbraco.org/projects/website-utilities/uwebshop/ this started out as a commercial package but has now gone open source.
    You can also have a look at Merchello, which is open source too - But if I remember correctly I think you get more out of the box with uWebshop than you do with Merchello where Merchello is more like a framework (Like Umbraco)...https://merchello.com/
    Otherwise I think TeaCommerce is probably a nice fit as well https://teacommerce.net/products/tea-commerce/ - But keep in mind that you'll need to buy a commercial license for this one.
    EDIT: Just re-read your post and since you focus on the "lightweight" part then Merchello might be the best fit.
    Hope this helps.
    Apr 26, 2016 @ 10:40
    Tor Erik Skogen
    Thank you so much Jan :) I think Merchello look like a ecom i can use :)
