  • Naveed Ali 161 posts 426 karma points
    Apr 26, 2016 @ 15:36
    Naveed Ali
    Button link help!
    I have a the following code which is a macro link.
    I am using umbraco v7
    It all displays fine BUT the button does not work.. I have tried changing the href to all sorts but still to no avail..It just opens up to the same current page or reloads the current page
    any help would be appreciated ...
        bool show = true;
        var url = Model.MacroParameters["externalLinks"];
        if (url == null)
            var targetNode = Umbraco.Content(Model.MacroParameters["target"]);
            url = targetNode.Url;
            if (targetNode.nodeTypeAlias == "File")
                var mediaNode = Umbraco.Content(Model.MacroParameters["target"]);
                if (wodc.code.UmbracoHelpers.isRecycled(mediaNode))
                    show = false;
    var targetString = Model.MacroParameters["showInCurrentWindow"] == "1" ? "_self" : "_blank";
    var linkTitle = Model.MacroParameters["linkText"];
    if (linkTitle == string.Empty)
        linkTitle = mediaNode.Name;
    if (show)
        var element = "<{0}>{1}</{0}>";
        var el = "h4";
        //if (!String.IsNullOrEmpty(Parameter.renderAsElement))
        //    el = Parameter.renderAsElement;
        <a class="btn content-link lrg" target="@url" href="@url">@Html.Raw(@String.Format(element, el, linkTitle))</a>
    Apr 27, 2016 @ 10:31
    Naveed Ali
    anybody please
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Apr 27, 2016 @ 13:19
    Nik
    Hi Naveed,
    When your macro renders to the screen, if you inspect source, what html is generated?
    Nik
    Apr 27, 2016 @ 13:25
    Naveed Ali
    Hi Nik,
    this is what is generated, as you can probably tell the target and href are blank.. whichi i believe is the issue it is not picking up the macro parameter target as a URL...
    <a class="btn content-link lrg" target="" href=""><h4>Council Tax</h4></a>
    Nav
    Apr 27, 2016 @ 14:00
    Nik
    Have you verified that the macro parameters are populated in the first place?
    If you are using Visual Studio, I'd put a breakpoint on this line:
    Then examine Model.MacroParameters to ensure it has values.
    If you aren't using Visual Studio try putting
    <div>@url</div>
    after the line mentioned above to see what it renders out.
    Apr 27, 2016 @ 14:11
    Naveed Ali
    Hi Nik,
    yes I have already done that and all the parameters are successfully coming through just on the line on the button the target and url do not come through I just get empty fields
    Apr 27, 2016 @ 14:28
    Nik
    So if you render out @url not in the link bit, then it renders out the correct url? (sorry just trying to clarify as I can't see anything wrong with the code directly).
    Apr 28, 2016 @ 08:40
    Naveed Ali
    Hi Nik,
    I have tried just @url..and there is nothing coming through ..which is very odd as on the var url there is data in there..
    seems to be the way I am outputting it on the button is not correct..
    Apr 28, 2016 @ 13:40
    Nik
    This might seem like a bit off an off the cuff idea, but try changing the name of the variable, just in case @url is trying to something specific. I know @Url (capital U) is a key helper.
    Apr 28, 2016 @ 13:46
    Naveed Ali
    Hi Nik,
    I have tried that unfortunately still nothing :-(
