  • Sam 7 posts 97 karma points
    Apr 27, 2016 @ 09:45
    Sam
    Error when publishing and saving.
    After transferring my local database/project to my live version, I started to recieve an error when trying to publish and save my content.
    Contact administrator, see log for full details. Undefined
    AppData/Logs:
     2016-04-27 02:39:08,874 [P37372/D15/T125] INFO  Umbraco.Core.Publishing.PublishingStrategy - Content 'LinoDB' with Id '1067' has been published.
     2016-04-27 02:39:08,936 [P37372/D15/T125] ERROR Umbraco.Core.Persistence.UmbracoDatabase - Database exception occurred
    System.Data.SqlClient.SqlException (0x80131904): Cannot insert the value NULL into column 'id', table 'LinoDB.dbo.umbracoLog'; column does not allow nulls. INSERT fails.
    The same error occurs for the table umbracoCacheInstruction.
    I'm not sure that it has something to do with permissions or like the Log shows something database-related.
    EDIT:
    Answer: http://stackoverflow.com/questions/36907464/umbraco-7-4-3-undefined-error-when-publishing/36908014?noredirect=1#comment61382066_36908014
  • Naveed Ali 161 posts 426 karma points
    Apr 28, 2016 @ 12:09
    Naveed Ali
    The error is kind of telling you the problem.. in your database the 'id' is set to not allow 'nulls'.. you need to access your database and amend this.
    There is tons of information on Google how to set a field to allow nulls in SQL.
    Will take you two minutes tops
    Nav
