  • John Churchley 272 posts 1258 karma points c-trib
    Apr 28, 2016 @ 09:15
    John Churchley
    Maximum Sting Length for Label Property
    I was wondering anyone new the maximum length a label can be?
    I'm using the content service to save to a property of property type label but keep getting the following error for long values "String or binary data would be truncated."
    Apr 28, 2016 @ 09:54
    Alex Skrypnyk
    Hi John,
    You can use this example how to built it - http://www.nibble.be/?p=285
    Apr 28, 2016 @ 09:58
    John Churchley
    Hi Alex,
    This doesn't relate at all to my question....
    Thanks for trying.
  • Manish 373 posts 932 karma points
    Apr 28, 2016 @ 12:17
    Manish
    Hi John
    Can you please elaborate more ? I did not get your question. Have you created macro?
    Thanks Manish
  • Naveed Ali 161 posts 426 karma points
    Apr 28, 2016 @ 13:39
    Naveed Ali
    Hi John,
    I think the max length is set to "0" which is 2.7 billion or something like that..other terms unlimited.
    If you can pinpoint the property editor code in your solution you can see what the max length is..if any..in there
    Nav
