Searching Forum solution with Active Directory Integration
I'm searching a good Forum solution to use in my intranet.
It must allow users to access through their own active directory credentials.
Furthermore there must be the possibility to create and manage categories and, if possible, sub-forums
Hello, I'm searching a good Forum solution to use in my intranet. It must allow users to access through their own active directory credentials. Furthermore there must be the possibility to create and manage categories and, if possible, sub-forums
Until now I haven't found anything of acceptable.
Can anyone help me?
I'm using Umbraco 7.4.3
Thank you Adriano
Adriano,
Try http://www.mvcforum.com/ it used to have umbraco package then it was created as its own standalone.
You should be able to swap out the membership provider to use active directory.
There are some posts on how to integrate with Umbraco have a look on our.umbraco.org.
Regards
Ismail
