  • Noel Fernandes 16 posts 80 karma points
    May 02, 2016 @ 19:51
    Noel Fernandes
    The target "AddUmbracoFilesToOutput" does not exist in the project.
    Hello All,
    I have developed this site in Umbraco 7 MVC and now would like to deploy it to a folder locally.
    Every time I hit the publish button, I get the below error message:
    Add Umbraco Files To Output
    I have searched quite a bit for the meaning of this message but hardly came across anything that would suggest a solution.
    I was wondering if any of y'all have come across an error like this.
    Please do let me know.
    Thanks in advance. Noel
    May 03, 2016 @ 05:28
    Hi Noel
    What does your deploy settings look like? Am I right in asuming that the "AddUmbracoFileToOutput" is the name of your publish target?
    Perhaps some screendumps would make it easier to help you out :)
    I don't think you will be able to figure out the error message by searching on the specific text since I suspect that it's a very specific error in your setup relating to the configuration of your publish target setup.
    Looking forward to hearing more from you.
    May 03, 2016 @ 12:34
    Noel Fernandes
    Hi Jan,
    Thanks for your reply.
    The deploy settings stored in a file called 'localpublish.pubxml' in VS 2015 looks as follows: enter image description here
    Screenshots of the error message that I get is as follows:
    Output Window in Visual Studio: enter image description here
    Error List in Visual Studio: enter image description here
    Furthermore, I have come across this link but can't make sense of what this has to do with the publish. I have yet to find out about this.
    Hope this helps.
    Thanks again, Noel
