  • Michal Koblasa 45 posts 139 karma points
    May 09, 2016 @ 08:17
    Michal Koblasa
    Language does not exist error
    Hello, we have weird situation on our umbraco system. Time to time, we encounter error - language missing: enter image description here
    If i open administration - host and domains, than second language is gone:
    Reuploading if binaries fix problem.
    We have version 7.3.4.
    What can cause this?
    Thank you
  • Bach Huong 6 posts 98 karma points
    Aug 28, 2016 @ 05:34
    Bach Huong
    Hi Michal,
    Regarding to the same report here • https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/74009-umbraco-loosing-reference-to-languages , this is an issue of Umbraco. You just need to upgrade yours to the next version 7.3.5 or later.
    I tried and it was fixed.
    Hope this helps you.
    Regards, Bach
    May 04, 2017 @ 10:10
    Michal Koblasa
    After upgrade it is ok.
