  • Rasmus Lynggaard 118 posts 325 karma points
    May 10, 2016 @ 09:43
    Rasmus Lynggaard
    Error generating models when using gridlayout - Umbraco v. 7.4.3
    I'm getting an error, when I'm trying to generate models when I'm using a grid layout datatype. The error I'm getting seems like a bug, but if someone has a solution it would be great :-)
    May 10, 2016 @ 10:12
    Hi Rasmus
    I recall seeing someone else get a similar error - Not sure that this is necessarily related to the grid - Stephan replied Craig here https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/75079-74-models-builder#comment-243330 - Perhaps some of the things Stephan is worth checking out in this case as well? Further details about Stephans exploration of the issue here https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/75079-74-models-builder#comment-243347
    Hope this helps.
    May 10, 2016 @ 10:32
    Rasmus Lynggaard
    Thx. I came down to, that I had a tab with the alias "content", which is also used by model. So renaming it to tabContent solved the problem.
