  • Limberg Michelsen 22 posts 99 karma points
    May 11, 2016 @ 09:38
    Limberg Michelsen
    Fresh uCommerce - unable to delete
    I installed newest Umbraco and uCommerce and then Avenue Clothing this morning.
    Put through an order and it seems to be working OK. I had a problem with the Umbraco\Config\Create\UI.xml file missing - downloaded it somewhere on the net and this seems to have solved it.
    But I can't delete anything in uCommerce and App_Data\Logs is not logging anything regarding this.
    If I delete a shipping method, a country or a payment method I get an error saying:
    Server error: Contact administrator, see log for full details
    Failed to delete item shippingMethod_10
    What is wrong?
  • Dennis Adolfi 1082 posts 6450 karma points MVP 7x c-trib
    May 11, 2016 @ 10:04
    Dennis Adolfi
    Hi Limberg.
    uCommerce uses http://eureka.ucommerce.net/#!/ for support questions and im not sure if they check this forum that often.
    Post your question there and they´ll help you, you often get help directly from someone at uCommerce and they are usally very quick at helping.
    Best of luck to you!!
  • Søren Spelling Lund 1797 posts 2786 karma points
    May 13, 2016 @ 07:41
    Søren Spelling Lund
    Dennis, thanks for pointing Limberg to Eureka.
    We do keep an eye on this forum, but we usually do exactly do what you just did: Point to Eureka, so we can track questions and cases more closely as to not miss anything :)
