var request = UmbracoContext.Current.PublishedContentRequest;
var found = ContentFinderResolver.Current.Finders.Any(x => x.TryFindContent(request));
If the URL is found, you can continue with the normal redirect. If not found, you can redirect to the non-de version.
Note that you may have to tinker with the above. I'm not sure if the list of finders includes the one that handles 404's (if so, found may always be true). Also, you may have to do something like clone the PublishedContentRequest and change the URL (e.g., if you need to add the "de" for the test).
404 Alternative
As an alternative, you could have your 404 page redirect to the non-de version of the page (if already on the non-de version of the page, the 404 would not do a redirect).
Multi language redirects
I have web site with 2 language:
Also I have Action filter which check User IP and if this IP from Germany we user go to mysite.com/de. So this is working.
My problem is that I wold like to use main web site mysit.com/page1 for German users, because I don't have mysite.com/de/page1 node.
Also I don't want to include this url(s) into redirect action filter to skip.
Please advise....
Thanks, Mike
Something like this might work:
foundmay always be true). Also, you may have to do something like clone thePublishedContentRequestand change the URL (e.g., if you need to add the "de" for the test).404 Alternative
I found that getbyroute method can help me, but this method is not working for descendants. it works with "/" but didn't works with "/login/"
UmbracoContext.Current.ContentCache.GetByRoute("/login/", true);
Thanks, Mike
