  • Poornima Nayar 106 posts 276 karma points MVP 6x c-trib
    May 17, 2016 @ 12:42
    Poornima Nayar
    Multi lingual site - setting culture programatically
    I am building a multi-lingual site. Instead of using the Umbraco languages for each site in the node I want each site to look up at at Site Config node and set the site culture from the property value set on the node. Is that possible? Any help much appreciated.
    Poornima
  • Cristhian Amaya 52 posts 423 karma points
    May 17, 2016 @ 12:49
    Cristhian Amaya
    Hi Poornima,
    before replying I've got to ask, what do you need to do that?
    And now, answering your actual question, you can use the thread culture, for example:
    var cultureInfo = CultureInfo.GetCultureInfo("es-ES");
    Thread.CurrentThread.CurrentCulture = cultureInfo;
    Thread.CurrentThread.CurrentUICulture = cultureInfo;
    Cheers!
    May 17, 2016 @ 12:57
    Poornima Nayar
    Yes I tried this and I didn't hit much luck!
