I'm pretty sure I've read something about this before, but I really can't find anything about it.
This is our procedure when updating:
Deploy to the Swap-slot
Swap the deployment slot with the production slot
The problem is that after we swapped, the application takes extremly long time until it works "normal" again (20-30 minutes). After the swap we can see that ApplicationStart is called, and Umbraco indexes up everything from the beginning. Are there any better ways to do this?
The same problem (ApplicationStart) is happening when we start a new instance. So when the site is slow and we auto-scale another instance, it takes 20-30 minutes before it even helps the site. Are there any good ways to solve this problem?
Azure + Umbraco + Slot Swapping and Auto Scale
Hi!
Best regards,
Robert
Hi Robert,
I think that Azure's auto swap feature can be configured to "warm up" the site before sending traffic to it.
https://azure.microsoft.com/en-gb/documentation/articles/web-sites-staged-publishing/#configure-auto-swap-for-your-web-app
20 minutes for startup is pretty extreme. I presume that CPU is at 100% during that time - have you done any tracing to see what's taking so long?
Jas
