Running Umbraco 7.4.3 using the new load balancing method.
"Publish at" schedules are not running. There is nothing in the logs to suggest an issue.
I'm not sure if it's a load balancing issue but not sure where to look to work out why publish at scheduler is not firing.
Publish at failing in load balanced environment
