  • Sam 7 posts 97 karma points
    May 25, 2016 @ 08:04
    Sam
    Multiple sites on same installation using different hosting domains
    I've created 2 different websites (Contents) on the same Umbraco installation.
    The first one is linked (Link to document) to the main domain, for example: www.carsandgadgets.com/cars which is registered with the same hosting-company as the server where all the files are on.
    The second should be linked to a domain differend from the first and registered with another hosting-company, example: www.onlygadgeds.com/allgadgets
    I tried to just edit the Culture and Hostname for the second site but without any luck.
    This is the first time trying this so I have no experience. Any help would be appreciated!
    EDIT:
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 9x admin c-trib
    May 25, 2016 @ 10:01
    102
    Hi Sam,
    You need to check the following:
    • Each of the two domains' A-Records (DNS) need to point to the IP of the server hosting the Umbraco installation
    • The IIS on the Umbraco server needs to have both of the hostnames added to its "Bindings" for the Umbraco site
    • Set the Culture and Hostnames setting for the two nodes, either just their hostnames or including the first step of the path if necessary.
    Hope that helps,
    /Chriztian
    May 25, 2016 @ 10:51
    Sam
    Hello, thanks for this fine answer. I've already tried your first solution but without luck (look edited question). Going to try second and third now.
    May 25, 2016 @ 10:54
    Ah - sorry if I didn't make it obvious enough:
    All of them needs to be done, to make it work.
    /Chriztian
    May 26, 2016 @ 11:00
    Sam
    It worked! The DNS needed some time to update itself. Thanks!
    May 26, 2016 @ 11:01
    Great to hear! :-)
