  • Saied 349 posts 674 karma points
    May 25, 2016 @ 18:19
    Saied
    Serve scaled image from cdn using ImagProcessor
    I have an image element like this:
    <img src="https://az824306.vo.msecnd.net/sctlwtsp/5015p_5416p_livewirets.png?width=73&height=73" alt="">
    I can't get this to resize when coming from the cdn, but it works if I have the image locally.
    Thanks Saied
  • Jeavon Leopold 3074 posts 13632 karma points MVP 12x admin c-trib
    May 25, 2016 @ 19:51
    Jeavon Leopold
    The Azure CDN cannot resize for you, it has to be processed before its pushed to CDN.
    I have a soon be released packaged called AzureCDNToolkit, I suggest you have a good read of the documentation to understand what's involved in getting setup https://github.com/CrumpledDog/Umbraco-AzureCDNToolkit
    May 25, 2016 @ 19:58
    Saied
    Jeavon,
    Thanks, I will have a look, so when this is released, would I be able to resize images coming from the cdn?
    Thanks, Saied
    May 25, 2016 @ 20:12
    Jeavon Leopold
    Step 1 and 2 of the documentation are about configuring the CDN and existing plugins for Umbraco this will achieve resized images coming for the CDN as is now. The Toolkit adds features on top of that such as fully resolved CDN paths instead of 301 redirects to CDN.
