How to add "SearchEngineSitemapChangeFreq" and "SearchEngineSitemapPriority" into document type?
Hi All,
I'm new to Umbraco, now I'm using Cultiv Search Engine Sitemap (Razor edition) package to generate XML sitemap.
My problem is in this XML sitemap package, I want to instruct Umbraco to re-generate the site map at anytime, and to change the frequency of automatic updates. And I saw a lot of people said for this issue, just need to add the property (SearchEngineSitemapChangeFreq) and (SearchEngineSitemapPriority) into document type, but I checked my data type list, did not found these two properties, thus I dont know how to add this into document type.
So is there anyone can tell me how to add these two properties into document type then can make my XML sitemap auto update and generate sitemap?
Also might be good to know that SEO Checker supports setting Change frequency and priority out of the box (not free)
http://soetemansoftware.nl/seo-checker
Hi All,
Thanks very much!
I think you need to check the get fundamentals video's to get started with Umbraco http://umbraco.tv/videos/implementor/
Also might be good to know that SEO Checker supports setting Change frequency and priority out of the box (not free) http://soetemansoftware.nl/seo-checker
Best,
Richard
Hi Richard,
Thanks very much! I've fixed this issue by adding frequency into my document type and template. It works now.
