  • Tim C 161 posts 528 karma points
    Jun 06, 2016 @ 10:08
    Tim C
    Using ApplicationContext.Current.ApplicationCache.Runtime
    I would like to store a small number of text strings in the runtime cache
    using Umbraco.Core.CacheHelper
    ie
    but after searching, I am not 100% clear on how to get and to set values - can anyone supply an example.
    I think I can use get to also set values but how would I update them once set?
    I have tried
    ApplicationContext.ApplicationCache.RuntimeCache.InsertCacheItem
    where I have created a class myObject and and instance rC but this crashes
    Compiler Error Message: CS0120: An object reference is required for the non-static field, method, or property 'Umbraco.Core.ApplicationContext.ApplicationCache.get'
  • Wayne 19 posts 59 karma points
    Sep 29, 2016 @ 06:10
    Wayne
    101
    I believe you need to work with an instance of the cache.
    var cache = ApplicationContext.Current.ApplicationCache.RuntimeCache;
    cache.GetCacheItem("rssFeed")
    cache.InsertCacheItem("rssFeed", ()=> { return nodeList; }, timeout: TimeSpan.FromDays(2));
