  • Andy 12 posts 92 karma points
    Jun 08, 2016 @ 14:56
    Andy
    Slimmage Issue
    I have added slimmage to a website by following the blog below
    https://umbraco.com/follow-us/blog-archive/2014/5/30/developing-a-website-with-responsive-images-using-the-umbraco-v714-image-cropper/
    I can see that the img's are getting wrapped with no script but the src property is not being set on the image, the data-src property is being set
    I have also noticed that slimmage is not outputting anything to the console.
    Has anyone came across this issues before.
    Thanks in advance,
    Andy
  • Mike 18 posts 39 karma points
    Jun 08, 2016 @ 15:21
    Mike
    It's sounds like the mark-up is there but the javascript part of Slimmage is not running - have you in included the javascript files in your HTML?
    Jun 08, 2016 @ 15:33
    Andy
    Hi Mike,
    Yes, I've ripped everything out into a test project and I'm still seeing the same issue, I have managed to get output to the console now which is as follows
    Slimmage: restored 1 images from noscript tags, checked 1 images, changed 0. 2ms
    If i inspect the dom the img src attribute is still not set
    Jun 08, 2016 @ 16:45
    Dennis Aaen
    Hi Andy,
    There have been some changes to the code how to get the crop out in a partial view, if you are using version 7.3.5+ of Umbraco CMS.
    Try to see this documentation https://our.umbraco.org/documentation/getting-started/backoffice/property-editors/built-in-property-editors/image-cropper
    Hope this helps,
    /Dennis
