The good thing is that you can turn this off if you want to.
So assuming you haven't changed anything in the content finders setup, you just want to remove that legacy handler. This would be in ~/config/404handlers.config, where you need to remove the line that contains
Dublicate content issue
Hi umbraco forum.
I have created a template that i am using in my content. It appears that i can find the template twice;
The 1st one is direct access to the template
The 2nd one is access to the content
What is wrong here? If it is like this, i will get dublicate content for every single page.
Hi Asger,
The reason why you can find the content twice is because of something that we call AltTemplate, you can see more about it here in this video below.
https://umbraco.tv/videos/umbraco-v7/implementor/fundamentals/templating/alt-template/
Hope this helps,
/Dennis
Hi Dennis.
I just tried implementing your solution. The content is no longer loaded, but i can still access the template.
Any idea how to fix this?
Best regards.
