  • Stephanie 39 posts 101 karma points
    Jun 24, 2016 @ 15:56
    Stephanie
    404 for Textstring View
    When adding a textstring to a doc type, I receive a 404 when viewing the doc type.
    Anybody else experience this? Couldn't find any info on it.
    Viewing the doc type - http://puu.sh/pEtJ8/97f839207b.png Datatype - http://puu.sh/pEtMp/62aa2913e8.png
    Jun 26, 2016 @ 06:16
    Hi Stephanie
    That looks a bit odd - What exact version of Umbraco 7 are you using?
    I'm wondering whether you have build a custom property editor for the textstring datatype? Or if you perhaps have installed a package that extends the configuration options for the textstring?
    I just checked the "textstring" datatype on a 7.4.3 installation since the options you have on the second screendump looked unfamiliar to me and when I checke the datatype on my installation it does not have the options to add style or markup. The only thing I can do is to change the property editor the datatype is based on. The textstring datatype is based on the "Textbox" property editor.
    So I suspect it might be a custom / 3rd party property editor conflicting with the original textstring somehow?
    Perhaps checking the /App_Data/Logs file can provide some more details on the error too? Check if there is anything marked with "ERROR" that could be related to this issue.
    Jun 27, 2016 @ 12:38
    Stephanie
    I will look into the possibility of 3rd party plugins causing issues, but I wanted to mention that I noticed that the Textstring datatype doesn't have the additional options, but if I create a new datatype and use the Textstring property editor, it does.
    http://puu.sh/pHKXh/79d85a3cd9.png - New datatype http://puu.sh/pHKYg/52378ed86c.png - Textstring datatype
    Jun 27, 2016 @ 12:39
    Stephanie
    Also, I am on version 7.4.3.
    Jun 28, 2016 @ 05:22
    Hi Stephanie
    Hmmm, I just checked my 7.4.3 install and I don't have an option to create a "Textstring" property editor...I have an option to create a "Textbox" property editor.
    The screendump of "Textstring" looks like something that is used with the "LeBlender" extension for use with the Umbraco grid? - Do you have LeBlender installed?
