Hi All,
I'm having this really weird bug that whenever i set either my MNTP / content picker to be compulsory.
When i save and published a node that contains this compulsory field (by leaving them empty)
The validation doesn't kicks in and i get the error below that pops up on the right panel.
When i check it in the console it says the below.
When i tried to load the POSTSAVE url on a browser it just says about the below
"The page you are looking for cannot be displayed because an invalid method (HTTP verb) is being used."
I've tried the url on other sites which is working with the compulsory MNTP field and it usually display the below instead
")]}', {"Message":"The requested resource does not support http method 'GET'."}"
Any idea what is wrong? Had wasted about 3-4 hours trying to figure things out but no luck fixing it.
Appreciate any help on this
Have you tried checking your Umbraco log (App_Data/Logs folder)? Is any exception recorded there after you perform this action? Maybe, if there is one, it can help pinpoint the cause.
Yup, i've checked the log. Didn't picks up anything there
It might not be the Postsave error. It seems like something is not triggering the angular properties validation bits. Can't figure out where
Found out what's the issue after I've created a new site on the same version and by copying bits by bits of the changes in.
I found out that it's due to the httpErrors tag within my web.config
I have my existingResponse="Replace" instead of "PassThrough"
<httpErrors errorMode="Custom" existingResponse="Replace"> <remove statusCode="404" subStatusCode="-1" /> <error statusCode="404" path="~/404/" responseMode="ExecuteURL" /> </httpErrors>
Umbraco 7.4.3 compulsory field validation error (on MNTP and content picker)
Hi All,
