public class ClientSurfaceController : SurfaceConroller {
[HttpPost]
public JsonResult GetClient(int Id)
try {
var repo = new ClientRepository();
var model = repo.GetById(Id);
// I use Automapper here to map data model to view model
// to keep it short here just returning data model
return Json(model);
catch (Exception ex)
return Json("Error: " + ex.Message);
Note that the naming of the ClientSurfaceController and the fact that you call it using ClientSurface are requirements. If you want to use just the GET then be sure to change HttpPost to HttpGet. This way you can verify your controller is returning data by browsing directly to sitename/umbraco/Surface/ClientSurface/GetClient and that should return result, if it doesn't then you can debug your controller. If it does then check js code and how you're handling the result or calling the controller.
Sorry for delay in getting back to you on this. It looks like your Ajax url doesn't match your controller.
I would take the Ajax piece out of the puzzle to start and just try to see if you can hit your controller action. You don't provide code sample of what your class name is and if it inherits surface controller or not.
As per my sample code, if you have the following:
[HttpGet]
public JsonResult GetClient()
return Json("Sample message");
Then you should be able to get a page that displays "Sample message" if you browse to the following url:
yourdevsitehostname/umbraco/surface/ClientSurface/GetClient
Then once you get a result by browsing to the url, instead of a 404 then you can try to call that url from Ajax. If you're still getting a 404 then your not calling the url for your controller and action correctly.
I Phill, problem solved. I made my Controller a SurfaceController and change the URL in my ajax to Umbraco/Surface/Controller/Client/GetClient.
I got one more question, how does Umbraco knows that all surface controller are in the Umbraco/Surface/Controller directory? Because I was checking my files and I couldn´t find the Umbraco/Surface/Controller directory.
Ajax using Jquery
Hi guys, I´m trying to use ajax using jquery, but I´m not getting the result that I want, here´s the code:
JS
Controller
I don´t why, but the example that I´m trying to do it´s returning me the HTML of the current page. Does anybody knows how to solve this problem?
Best Regards
Here's a snippet of code that I use that works for me (in this case I'm posting an Id to get a single item, but similar idea):
Then the controller:
Hope that get's you in right direction.
Cheers, Phill
Hi Phill, still not working, but now it´s returning me a 404 message. I made the following changes:
JS
Controller
Then you should be able to get a page that displays "Sample message" if you browse to the following url: yourdevsitehostname/umbraco/surface/ClientSurface/GetClient
Hope that helps. Phill
Best Regards
Hi Vanilson, All locally declared surface controllers get routed to:
/umbraco/surface/{controllername}/{action}/{id}
They do not get routed via an MVC Area so any Views must exist in the following folders:
~/Views/{controllername}/ ~/Views/Shared/ ~/Views/
Here's the documentation: https://our.umbraco.org/documentation/Reference/Routing/surface-controllers
// Herman
